11-27-2018, 02:07 PM | #1 |
rhino 250 Winch and mounting plate...
greetings folks.
new member here. I just purchased my rhino and will be installing modifications that I have read about on the site. I will be installing a winch so I am looking for what brands you folks have installed and what brackets are needed to install on the rhino. didn't see what I needed doing a search so I thought I'd post my first question. oh and please reply where you purchased. thanks |
11-29-2018, 05:45 PM | #2 |
I used the Harbor Freight atv winch https://www.harborfreight.com/2500-l...rol-61297.html
Later added a synthetic rope line after I found out cable sucks when it gets a little frayed and a little wire stabs your hand.. https://www.harborfreight.com/atvutv...kit-63139.html The included fairlead wont allow you to suck in the hook like the stock one does. When it happens it sucks too. I made a rubber anti suck puck out of a cheap rubber mallet .... works well. For brackets I used what came with the winch and some angle iron to bolt it to the frame in multiple points to not put too much stress in just one spot. |
11-29-2018, 05:53 PM | #3 | |
11-30-2018, 11:25 PM | #4 |
thanks for the replies..much appreciated!
12-02-2018, 08:59 PM | #5 |
This is how i did my harbor freight winch with winch mounting plate also purchased from harbor freight. I made additional mounting plates to sandwich the taotao frame. starts on the 9th picture down hope this helps.
http://chinariders.net/showthread.php?t=20909 Last edited by PANDEMIC; 12-04-2018 at 01:22 PM. |
12-06-2018, 02:31 PM | #6 | |
12-09-2018, 12:56 PM | #7 |
in hindsight, I wish I would have made my sandwich plates a little longer so I could have added another bolt on the outside of the taotao frame also.
12-09-2018, 02:39 PM | #8 |
I noticed that and made mine a tad longer so the bolts on the right side are outside the frame.
12-09-2018, 03:31 PM | #9 |
so did you get it all together?
12-09-2018, 05:02 PM | #10 |
yes..everything is installed..still have to paint the brackets tho...too cold here to do it now.
12-09-2018, 05:33 PM | #11 |
where are you located? I am here in Milwaukee, WI
05-01-2021, 11:12 PM | #13 |
Can you post pictures? I followed the link to your thread where you posted pictures but the links are no good. I would love to see how you did it.
05-02-2021, 09:03 PM | #14 |
There are a couple of winch mount mods on my thread.... mine as well.
http://www.chinariders.net/showthrea...t=16553&page=2 |
