Old 10-09-2018, 06:19 AM   #1
Nandor   Nandor is offline
Nandor's Avatar
cg250cc mini trike turbo update! finally on,
Hi all after a bit of advice im wanting to get as much power as i can out of a zonshen 250cc have been thinking i mightdo a drawthrough carby turbo.
I have just finished cleaning up the motor to replace the tired 200cc lifan i have in it but really want to get the most out the cg250
So any advice to squeeze some extra power would b great
Old 10-09-2018, 09:20 AM   #2
kirbo7106's Avatar
Greetings!
Welcome to the forum! Nice trike! Way to start with pictures! Is it me or is that like an adult version of a Big Wheel?!? Ok, adult is probably not the correct word to use. Calling most of us “adults” is...well...yeah, you get the idea!
Ok, back to the “older” person Big Wheel! That is so awesome! I know we usually ask for pictures, but this deserves a YouTube video!!!
I can’t really help you with the turbo, but I’m sure some of the other members can.
Enjoy the Ride!
Dan-O
-2018 Tao Tao HellCat - DOA
Old 10-09-2018, 09:36 AM   #3
Bruces   Bruces is offline
That looks like a lot of fun .
Old 10-09-2018, 02:44 PM   #4
Nandor's Avatar
Thanks guys been a labour of love building this over the past 3-4 years, adding bits and improving what i can.
Ill try find a video for u so u get to see how small it really is but still gets up and moves, have got 83km/h out of it on dirt in third but ran out of space to wind it up any more
Old 10-09-2018, 04:02 PM   #5
roundhouse   roundhouse is offline
roundhouse's Avatar
looks cool! there is a turbo thread in the dual sport section but i do not think anyone has tried it. if you figure it out let us know.
Old 10-09-2018, 06:42 PM   #6
Nandor's Avatar
So far im planning on getting a tunable cdi so i can avance the timing if need be
will b running a 34mm makuni carb with adjustable needle and set the jets
Will also b running a air/fuel gauge with warning light to ensure i dont run it to lean
i will have a separate oil tank with pump and oil cooler so i dont risk starving the motor of oil and ill run the pump on a timer like a turbo timer so it continues to pump oil round after the motor is stopped to cool down the turbo and get excess temp out
Will start off at low psi round 4psi and wind up from there
All this together and a propper dyno tune before i ride it should hopefully keep it from blowing up fingers crossed!!!
Old 10-10-2018, 10:43 AM   #7
ben2go   ben2go is offline
The crankshaft is pressed together from my understanding. If that is true, you won't get much pressure in the engine before the crankshaft separates. I've seen quite a few failed pistons in these engines that are run in the Bobber. That would be the next weak link.
Old 10-10-2018, 12:19 PM   #8
Honestly, that first picture made the hair on my arms stand up.
It looks like a jockey shift and a hand clutch; is that right?
Old 10-10-2018, 02:13 PM   #9
Why is the front brake caliper on the opposite side?
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 10-10-2018, 02:44 PM   #10
Nandor's Avatar
Yeah its a suicide shift clutch to take off just slam gears lol
Old 10-10-2018, 02:45 PM   #11
Nandor's Avatar
Thank u for that ill look into it further
Old 10-10-2018, 02:48 PM   #12
Nandor's Avatar
Gd spoting, was wondering if anyone would pick that up lol
im changing the bottom mounts on the shocks and just sat it together to get it mobile. bloody things have corroded themselves on there rather well
Old 10-12-2018, 10:47 AM   #13
Do you plan to engineer a foot clutch?
Old 01-12-2019, 07:09 AM   #14
Nandor's Avatar
Nah not at all if i was going to chsnge vfb the clutchni would put it on the suicide shifter
Old 01-12-2019, 12:00 PM   #15
bogieboy   bogieboy is online now
bogieboy's Avatar
looks like a very fun project... i built this about 6 yrs ago now.... was a hoot to ride.... had an old honda 75cc engine in it....
Search this Thread:
Advanced Search
Display Modes
