08-19-2018, 07:42 PM | #1 |
Taotao 250 rhino, too stiff..
Looking for someone who has an Idea of where I can purchase adjustable shocks to fit my taotao 250 rhino (200cc).. The shocks that came on the thing are to long or the springs too stiff or both. A 259 lb friend of mine could hardly make the suspension go down when he bounced on it! When I ride it the suspension stays topped out and bangs over bumps.... Anyone have a solution for my problem ? Thanks, Koon67
08-20-2018, 11:22 AM | #2 |
shocks
see your dealer where you got it from
08-20-2018, 11:51 AM | #3 |
Do you have the perches adjusted to the fully soft position?
08-20-2018, 01:14 PM | #4 |
Thanks for your time, I will check them out...
08-20-2018, 01:18 PM | #5 |
I have one more softer notch left on the front but I think I will need more than that. I will try that first though! The rear is at it softest position.... Thanks for your input...
08-20-2018, 02:41 PM | #6 |
I bought a pair of fronts from EBay item# 322578000342. Definitely better ride than original but should have bought 375mm instead of 400mm. One has started leaking slightly. Currently looking for a better rear shock.
08-22-2018, 05:46 PM | #8 |
They're RFY brand. Adjustable spring preload and air pressure.
atv, shocks, suspension, taotao rhino 250 |
