Old 07-22-2018, 10:19 AM   #16
Cravin01   Cravin01 is offline
Cravin01's Avatar
Good luck with it and glad to see Don getting after it. Hopefully you get the parts in quick, Aluminum melts at 1220' F, is there any concern of other damage than the topend, possibly aluminum chunks un the case?
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 07-22-2018, 10:45 AM   #17
tomrom   tomrom is offline
Bad Rectifier? I have no idea what caused this.
2017 Bashan Storm
Old 07-22-2018, 10:53 AM   #18
Cravin01's Avatar
I have no experience with a meltdown like this either, hopefully it can just get a afew new part and be ok.
2017 Bashan Storm
Old 07-22-2018, 11:54 AM   #19
Sochin   Sochin is offline
Sochin's Avatar
I'd say a valve dropped and caused total meltdown, hope you get it covered under warranty indeed. That would require just get a new complete engine. Too much debris cycled around the oil vanes by now.
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
Old 07-22-2018, 01:01 PM   #20
ben2go   ben2go is offline
Yep, dropped exhaust valve as I suspected. If the engine was running lean, the exhaust valve could have overheated and popped. If not, it was a bad valve to begin with.
Old 07-23-2018, 09:26 AM   #21
blanc12   blanc12 is offline
Looks like it got hot. really hot. Is your carb stock?
running too lean can do this.
You may want to fatten it up.
Old 07-23-2018, 09:46 AM   #22
zippy   zippy is offline
On old VW automobile air-cooled engines a dropped exhaust valve was a frequent problem. If an exhaust valve was adjusted too tight, then when the engine got hot and the metal expanded, the gap between the end of the valve and the rocker arm would disappear entirely. Then when it got even hotter the valve would not be able to fully close; the hot valve would not even contact the cylinder head. Since the metal of the valve did not contact the metal of the head (did not seat with it) it could not dissipate its heat to the head. While this was happening more hot exhaust gases would rush around the now slightly always open valve and get it hotter still, until it would get so hot it would eventually break off and fall into the cylinder causing destruction. Maybe that was the cause here.
Old 07-23-2018, 10:50 AM   #23
Yes, Stock.
2017 Bashan Storm
Old 07-23-2018, 10:52 AM   #24
Could be, however there was the recommended gap.
2017 Bashan Storm
Old 07-23-2018, 12:45 PM   #25
Originally Posted by tomrom View Post
Yes, Stock.
Could have been too lean. The intake was still there because the air/fuel coming from the carb cooled it. The exhaust valve over heated along with the piston.
The new or repaired engine could do the same thing without adjusting the jets in my opinion.
Old 07-23-2018, 02:33 PM   #26
Gh426   Gh426 is offline
Could be the timing was too advanced also, that will burn/melt thru a piston also.
Old 07-23-2018, 05:37 PM   #27
Cravin01's Avatar
The stock carb on the Bashan Storm has a 105 main jet in it so I'd be surprised if the carb was too lean.
2017 Bashan Storm
Old 07-23-2018, 07:34 PM   #28
The damage to the piston is more than just a dropped valve. It got really hot. Lean mixture is the most likely reason.
Old 07-23-2018, 07:54 PM   #29
ChrisWNY   ChrisWNY is offline
ChrisWNY's Avatar
If it was so lean that the engine melted down, wouldn't the engine have stalled or bogged down with the choke off? Usually super-lean engines won't run unless they're choked (or they bog badly when the choke is off).
2018 RPS Hawk 250cc
Mods so far:
1. Mikuni VM26 Carburetor w/#115 main jet
2. 17T/45T JT sprockets
3. JT 428 X-ring chain
4. Air box mod
5. Hawk Digital Cluster
6. Aftermarket IMS shift lever
7. Performance Aftermarket Exhaust
8. 295mm Nitrogen Gas Monoshock, 20W oil front forks
Old 07-23-2018, 08:46 PM   #30
Normally I would agree but timing is locked in on most motorcycle engines.
Search this Thread:
Advanced Search
Display Modes
