05-07-2018, 08:29 PM | #1 |
Valve Adjustment.. Where did I go Wrong?
So I have been trying to adjust the valves in my new Magician. I've followed all the directions I could find but my valves still sound VERY loud. tap tap tap..
I found TDC (The T mark) on what I think is the compression stroke. I say I THINK because I pulled the plug and saw that the piston was at the top (I rotated the cam again and watched the piston move down to be sure).. Then I proceeded to carefully set the intake and exhaust to 0.003. My question is can the piston be at the top and the T mark set and not be at TDC? It's really sounds loud but I have nothing to compare it to. If I had audio of a properly adjusted Hawk engine that would be helpful. Its a pain in the a$$ with the magician since most of the plastics and the tank have to come off.. |
05-07-2018, 09:48 PM | #2 | |
05-07-2018, 09:49 PM | #3 |
did you use the dot on the cam gear? or the number one stamped on the gear as in between the 2 head bolts marking? sure you know better to use the dot to dot as top. some videos out there say to use the “1” which is incorrect.
05-07-2018, 10:12 PM | #4 |
Are you talking about an overhead cam engine? This is a pushrod engine....ARH
05-07-2018, 11:10 PM | #5 |
Easy way to know if you have the correct TDC is to watch the intake valve. Once it starts moving the next T mark will be TDC for the compression stroke.
05-08-2018, 12:00 AM | #6 |
OK Look at this picture. on example 2 and 4 the piston is making its way to TDC. But As ARH noted only in pic 2 are you on your compression stroke. note the valves in pic 2, both are closed. in 4 the Exhaust is open. so TDC happens at 2 and between 4 and 1. Hope that helps.
adjustment, hawk, magician, valve |
