Old 04-16-2018, 01:14 AM   #1
bikehelp   bikehelp is offline
Engine help please!
I took the front head of my bike to clean, clean cam and adjust valves. Now my bike sounds like this. Did i break it?
https://streamable.com/s/5uk3l/xkwypf
Old 04-16-2018, 12:43 PM   #2
Can anyone help? Is timing off?
Old 04-16-2018, 01:20 PM   #3
franque   franque is offline
It sounds like there is either a vacuum leak somewhere, or a breather hose is unplugged. Do you feel any inordinate puffs of air anywhere? Also, you put a new exhaust gasket on it, yes?
Old 04-16-2018, 02:05 PM   #4
A gasket were the exhaust pipe connects? I used the original, well there wasn't really one it was pretty shredded look worse then these.
Old 04-16-2018, 02:47 PM   #5
I think its my intake. One of the top bolt that hold on the intake pipe was recently retapped. I sprayed carb starter on the spot and the RPM jumped up.
Can i use some high temp silicone to seal it?
Old 04-16-2018, 02:52 PM   #6
ben2go   ben2go is offline
You'll need to replace those parts. Silicone getting into the engine will be bad.
Old 04-16-2018, 03:05 PM   #7
Ok then, If it is confirmed the leak is do to the retapped intake bolt on the Cylinder Head. The only way is to replace the Cylinder Head Assembly?
and if so how do you measure valves to determine head size? 52.4mm or 54mm cylinder head
Old 04-16-2018, 03:10 PM   #8
You can repair it with a helicoil kit or a time-sert kit that fits the thread size of the bolt that came out. You will need a small drill for the job and red high heat loctite. There are vids on youtube explaining how to do it.
Old 04-16-2018, 03:13 PM   #9
I was thinking about helicoil repair on it, should of done that instead just trying to retap, but if i do just get a new head would this work? Looks the same, not sure?
https://www.ebay.com/i/232101248895?chn=ps
Old 04-16-2018, 03:24 PM   #10
Yes, if it's the same and for the same diameter cylinder. The valve size should be the same if it matches the cylinder size. You may need to measure your cylinder's inside bore to be sure.
Old 04-16-2018, 04:16 PM   #11
Bruce's   Bruce's is offline
It’s probably not leaking because of the threads as long as they are solid ,it’s more than likely the intake is cracked ,or the gasket is not sealing properly
Old 04-16-2018, 07:50 PM   #12
No it's not cracked, Its this bolt, I covered the area with my figure and the noise stops.
So i just put a little black high temp silicon around that bolt gap. Will see tomorrow.
Old 04-16-2018, 08:38 PM   #13
it Looks like there is a gap between the bolt head and the intake ,try a washer or two in there to take up that gap .Also ,you may try a thicker gasket or oring depending on what it has .
Old 04-16-2018, 08:41 PM   #14
Hellkitty   Hellkitty is offline
Hellkitty's Avatar
That looks like a 125cc engine found on Taotao products. Probably a 54x54 square bore. Is that a Taotao Hellcat?
Old 04-16-2018, 08:53 PM   #15
lonfu   lonfu is offline
Looks like your bolt is cross threaded. I would pull it and re- thread the hole to see if you can save it with out a heli-coil.
2007 4x4 300 buyang atv <br />2009 4x4 300 Buyang atv<br />1985 yamaha v-max/2009 fuel inj Yamaha Rhino
Search this Thread:
Advanced Search
Display Modes
