#16 | |
#17 |
Check your pivot hole in the handle where the cable end sits. Sounds like a burr not allowing the cable end to pivot. That was an early Victory issue. "The Dreaded Burr".
#18 | ||
![]() and a vid... sounded mean... Last edited by bogieboy; 07-19-2016 at 09:16 PM. Reason: edited for speed inaccuracy |
#19 |
Holy cow! That's an animal! :-)
#21 |
interesting that you ask GlennR... i just installed one LAST NIGHT...LOL i had a random left hand master cylinder from an old john deere atv in my posession, and installed it with one of these... sooooooo nice and smooth.... took almost a half hr just to bleed though.... i can post some installed pics tonight...
#22 |
That style of slave cylinder is a pain in the butt to bleed. I have done one so far, and the best method I have found for them is to elevate the slave above the master somehow, and then bleed it uphill. Really awkward to do without a bleed screw too. Another method that worked fairly well was to set the slave on a rack or tray over something to collect dripping brake fluid, crack the banjo just enough to start a slow leak, and gravity bleed it. This method takes forever though.
In either case, pre-filling the slave with a bit of fluid and cycling it a little to get the air out will help immensely.
#23 |
Cables are so much simpler. Otom makes a nice brace that stops the flexing of the retainer issue and makes the pull a tiny bit lighter:
![]() I have a Karoo trials bike that I never ride because of the broken hydraulic clutch. It's just a bigger pain than it's worth. |
#25 | |
#26 |
Must....resist....clicking.....
#29 | |
#30 | |
Well... it's Taobao. 6 pictures doesn't mean you get six of them. There are probably some less expensive vendors, I just posted the first one I found. I'll see if I can find the actual link I bought from. Seems like it was $8 or $9. |
