02-26-2017, 03:20 PM | #1 |
Help i screwed up
i went to take off my brake reservoir on my MAGICIAN 250 and i stripped out the screw i swear i didn't but that much force on it on it but then i had to drill out the old screw i put in some screws in that appeared to be the same size but now my brake reservoir lid leaks slightly even when the screws are tight what do i need to fix the dripping or find a replacement part when i screw something i screw it up good
02-26-2017, 03:47 PM | #2 |
from what i remember of the stock brake reservoir screws, they are VERY short... i would double check that you arent bottoming out the screw in the hole before its 100% snug on the lid... i got rid of my stock reservoir and went to a set of these in blue...
02-26-2017, 05:32 PM | #3 | |
02-26-2017, 06:15 PM | #4 |
Is the o ring gasket still present ? The screws are typically a tapered head ,is that what you used ?
02-26-2017, 07:56 PM | #5 |
have to use tapered head screws not sure washer would work
02-26-2017, 07:58 PM | #6 |
yep matched them to the originals as closely as possible
02-02-2018, 03:43 AM | #7 |
What's a good throttle replacement and what's a link on the clutch and levers that will fit the magician
