FNG with 3x CG200 Need Head Gasket:RSVL,CA
Its my sons fault..
He bought the first one, Then couldn't resist a second one. And now picked up a third. All 3 are basically the same bike: Zongshen CG200cc ???? Seem to all have the 163FML motor but badged as Yamoto, Cobra and a KPX. Yamoto ran out of oil and torched the con-rod bearing. Work in progress fixing that.. However I am desperately searching for a HEAD GASKET! bought a seal kit that seemed close but no joy. I can get crafty and cut other gaskets if I have to but need a fresh head gasket. See pics, any leads or wisdom appreciated! Tim in Roseville, CA |
OHC (CB)
![]() OHV (CG) ![]()
that set of CB200 gaskets with the cylinder kit looks like a match! how to get! where can i buy? can i buy just that gasket set?
OHV vs OHC ? 162fml vs 163fml? this set looks like what i need: http://www.ebay.com/itm/180483848185 Last edited by TGubbins; 11-19-2017 at 01:46 PM. |
https://www.ebay.com/itm/292144726118 is one of those matches 63.5mm
--- btw. that shape also found in the weirdo 69mm which are difficult to find in US ![]()
Last edited by humanbeing; 11-19-2017 at 08:01 PM. Reason: Fix grammatical errors |
excellent! thank you for the help!
You may know this answer so i will ask: what is the crankshaft cam chain sprocket alignment? align tooth or trough to tdc keyway? i foolishly pulled mine off the crankshaft without marking it. as a last resort i could open up one of my other 163fml cases to see but i would really rather avoid it. |
Official answer is in http://www.ctx200.com/files/xl200_workshop_manual/
WiSiWYG in http://www.motorfans.com.cn/forum.ph...uthorid=343764 15# & 16# Google 's translation is readable ![]()
Excellent resources! THANK YOU
Sadly not really getting the angle to see what I need. I'm going to start a new thread as this has headed way off gaskets THANK you HumanBeing |
cg200 163fml headgasket |
