07-19-2017, 06:11 PM | #1 |
Shorter Foot Shift Lever for RX3
Howdy,
I'm looking to purchase a shorter foot shift lever for an CSC RX3. I find the stock lever a little too long and have to slide my foot forward to get a good contact with the shift lever. Can any of you folks suggest or recommend an after market shorter shift lever that will fit the serrated transmission mounting point? A recommended source and/or a recommended brand would be greatly appreciated. |
07-19-2017, 09:36 PM | #2 | |
Thanks for the reply. A shift lever that is 1/2 inch shorter would probably work fine. But when I clicked on the Amazon site and read the specs of the foot shift lever, they seemed weird. It stated the foot shift lever was 11.9" X 5.1" X 1.3"????? I can't figure out where they were measuring on the part. So, I measured from the front of the left rider's foot peg to the back of the rubber contact tip of the lever and the distance between measured 5 & 7/8". So you said that the new lever is 1/2" shorter than the stock foot shift lever. So does your new replacement lever measure about 5 & 3/8" when measured the same way as I measured my lever? And the shift lever part is listed as for a '93-'03 Honda XR650L bike. |
07-22-2017, 01:49 AM | #4 |
I have the EMGO also. I noticed when I put it on it was closer to the engine and made it harder for me to hit for upshifting so I bent it out a bit. Easy to do and it's held up well.
2017 BMW F800GS Adventure |
07-23-2017, 02:35 PM | #5 |
Notice any clearance problems?
jontando,
Did you notice any clearance problems between the engine and EMGO gear shift lever when you installed it on your bike? |
07-23-2017, 09:43 PM | #6 |
