04-20-2017, 09:44 PM | #1 |
Stretching China bike
Anyone have success stretching one of the grom clones? If so what kit did you use?
04-20-2017, 10:20 PM | #2 |
Assuming you're referring to stretched swing arms, there is nothing. You're own your own. These are cheap Chinese bikes with little aftermarket support.
04-20-2017, 10:27 PM | #3 |
Completely understand that, I'm questioning whether adapting a kit for an actual grom will work or somewhat work, if dimensions are completely off or it's doable with motivation and the right tools
04-21-2017, 03:44 AM | #4 |
I added 75mm 3" into the frame of my boys pit bike..
cut the frame under the tank and added it there.. ...
04-22-2017, 11:15 PM | #5 |
I'm sure enough money can be thrown at it and something fabricated. I know nothing from the grom aftermarket that would bolt right up. There were some aftermarket extended swing arms for the Grom. Still not a cheap option.
04-28-2017, 12:31 AM | #6 | |
06-26-2017, 08:43 PM | #8 |
Well then. Can you post more info for others to benefit from?
06-27-2017, 01:58 PM | #9 |
the swing arm fit s with a litter modification, there is a litter over lap inside the arm, the way it was constrcted you have to modify the extencion where the over lap is and the corners too. it is the four cornner i did my with a hand dremel
i made a drawing to show what i did |
