Here are the mod pictures:
http://imgur.com/a/PamSn I ordered this harley brace and drilled holes in it: http://www.ebay.com/itm/252955960539 All in all I'm happy with the front suspension being a bit stiffer! I only have an hour of riding on it thus far so I'll get back to you all once I've field tested it a bit more! |
#3 | |
The reason the aluminum clamp is more difficult here is because the tire/wheel would interfere with a straight across clamp so you'd have to machine a much larger block of aluminum. |
You would put it up higher on the forks.
#5 | |
I think yours looks cool and it appears to fit very well.
That would interfere with suspension travel, and not brace the parts I want braced.
The reason I want the lower part of the fork assembly braced is because these were rotating ever so slightly, allowing the wheel to turn about +/- 2 degrees from the handlebars. At higher speeds on uneven ground this manifested as a slight "speed wobble". The brace I used prevents lower fork twisting which helps to minimize wheel flop. |
Nice job.
I am still on a quest for a clamp style that may work, There are a couple of possibilities, but if they don't pan out then I am going this route. Many older hondas used a similar idea to integrate a fork brace with the front fender, and trust me it makes a difference! For 20 bucks and some time drilling a couple of holes, can you really complain?
This is, by far, the biggest benefit to USD forks. With the fat tubes being in the clamps and very long, it is far more rigid than a standard fork.
Good idea! The TW200 uses a similar brace as a fender mount, to contend with skinny forks and a 4.00-18 front tire.
#14 |
awesome write up, thank you. Does it completely clear the knobbies, or is there some rub?
#15 |
It clears with plenty of room around the tire. Take a look at his pictures and if you go to the 5th one down you see a straight on shot showing plenty of air gap around the tire.
brace, front forks, hawk, suspension |
