#16 | |
#17 | |
![]() ![]() ![]() I wonder what happens when a china bike hits 88 miles per hour... probably need a Flux Capacitor for it to go any faster
#18 | |
#19 |
What are the two aluminium screw caps for on the valve cover? They look like the same casting as the oil cleaner cap on the 229cc Zongshen motor.
I'm curious about the head clearance on the frame. |
#20 |
That to access the valves for adjustment. It has a overhead cam. After comparing dimensions between this engine and the Hawk engine it looks like it will be almost a direct bolt up. Looks like close to the same clearance on the head. I'm trying to find more detailed dimensions on it to varify.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 04-13-2017 at 02:12 PM. |
#21 |
Seems to have Smog/air machining on cylinder head. Plus, it has a 15 tooth sprocket, carburetor and CDI.
#22 |
I saw that. Make me think this is EPA approved. The latest list of EPA approved motorcycles has the Loncin LX250-8 as approved. I wonder if this is the same engine that is on that bike?
#23 |
I tried to contact them to see if we could import these and I never got a reply.
#24 | |
#25 | |
#26 | |
![]() Daaaaang! You're pushin 8 feet tall?!? I'm almost 5' 10" on my good days (those moments right after a Chiropractor appointment)... we must look like ants to you giants ![]() Just do a good tuck... we are all the same height when our face is buried in the headlight plastics ![]()
#27 | |
#28 |
man oh man a hawk with a 6 speed and oem 15/50 sprockets and that 6th gear as an overdrive would be perfect!
#29 | |
#30 |
Seats...? We don't need seats where we are going! (Just our bathing suits)
