03-19-2017, 03:43 PM | #17 | |
Fantastic idea! You inspired me to snatch one up off of EBay that has 2 USB ports for charging devices on the go. Under $12 shipped, how can you beat it? |
03-20-2017, 08:26 AM | #19 |
I was looking at something similar except it has 2 USB ports. I was trying to figure on how to mount it. Now I know how. https://www.amazon.com/LiDiVi-Waterp...f_rd_i=desktop
03-23-2017, 08:30 PM | #20 |
Installed +12V external socket. No more problems with charging the tablet, the smartphone, etc. on the go (with adapter). One may connect a small compressor if a flat tire somewhere on the side of the road. No need to remove side cover to charge the battery periodically during long winter shutdown.
Purchased here for $1.50 - http://www.ebay.com/itm/Waterproof-1...kAAOSwSdZWglPQ |
03-24-2017, 01:05 PM | #21 |
Where are ya'll picking up power for the voltage meters? If I add much more, I'll need to add an aux power block.
2002 Goldwing 2016 Hawk |
03-24-2017, 01:06 PM | #22 |
I would wire the volt meter into one of the many "Key/Ignition ON" sources... grab a volt meter and find what you need
03-24-2017, 04:17 PM | #23 |
Great write up and my God that thing is clean! I thought mine was looking good smh....
2005 Kazuma Cheetah 200 (Swamp Thing) |
03-25-2017, 12:20 AM | #24 | |
03-30-2017, 06:05 PM | #25 |
Which shifter boot did you order and how long did it take to get it?
03-30-2017, 06:17 PM | #26 |
Suggestion for your seat; do as I did but add padding between the Coleman Comfort Ride and your seat.
03-30-2017, 10:48 PM | #27 | |
It took about three weeks, don't remember exactly. |
03-30-2017, 10:55 PM | #28 |
I like your idea, but I am planning totally reconstruct the seat with adding and reshaping foam padding inside. I have already purchased nice marine vinyl cover from Hobby Lobby.
07-21-2017, 01:33 AM | #29 |
Did you ever get around to doing it?
07-24-2017, 09:16 PM | #30 |
Please check my thread - http://www.chinariders.net/showthread.php?t=19578
