RPS Hawk -- Blinkers
I just purchased a used hawk and can't wait to take it out. There were a couple things wrong when I bought it the horn didn't work, the battery was bad, and the blinkers don't work. I fixed the horn and changed the battery but still can't get the blinkers working. When the switch is flipped the annoying beep turns on but no lights. Any idea how to fix it?
Thanks in advance. |
Honda shop manual https://josemaco.files.wordpress.com...h-62ktjam5.pdf 18-16 / p.326 gives u the right idea
![]() Happy hunting the ![]()
check all the connections especially at the rear some of those cables were really short and pull apart real easy. could be bulbs too. undo the connection and put straight 12volt to em.
I was just about to post to check the bulbs--I had the same thing happen on my old TMEC 200 enduro with the turn signals, and just as I was about to check everything and anything, I noticed that both of my front bulbs needed replacing.
I have posted this picture before. My Hawk came with the rear fender on it. Didn't post the second picture before. The wiring goes up the left side of the frame. If you want more pictures my bike is in the entry way so I can look at it and work on, because I can.
Right next to the formal dining hall .
I consider the same except opposite, when it's 99 degrees and high humidity ![]()
#7 | |
I have great paint skills and you will see the entryway with a perfect red rectangle around it. That tree makes it look like roof is not straight. ![]()
Thanks!
Thanks guys, I bypassed the blinker relay and the lights turned on but obviously no blinking so I ordered myself a new blinker relay. I switched out the blinker relay and they all magically turned on and started to flash.
