11-18-2016, 11:30 AM | #1 |
10,000 mile maintenance
Hey all, just getting close to the 10,000 mile mark on Chang (my RX3), be a year in Feb since i got him. Been truly a trouble free run thus far. Only things that went wrong on my bike is the mechanic (me!). Been able to get thru it all with the help of CSC (Gerry's the man), this forum, fellow owners, etc. I've been thru the manual and follow the maint to the letter. Just curious with the 10,000 mile mark coming up if ya'll got some opinions on what needs to be looked at or done. Thanks!!!
11-18-2016, 12:14 PM | #2 |
My maintenance list
Here is my Maintenance list.
Pre-Ride Check List - http://www.msf-usa.org/downloads/T-C..._Checklist.pdf Periodic Check Rear Brake Pedal - 10 to 20mm of free play Front Brake Lever - Brake Fluid - 1/8" from top - Replace fluid if spongy Brake Pads - Replace when < 1.5mm - http://www.cscmotorcycles.com/Articles.asp?ID=256 Brake Rotors - < 2mm thickness Chain Adjustment or Replacement - Keep at .75 to 1.25 inches of slack - After a few adjustments replace the chain - http://www.cscmotorcycles.com/Articles.asp?ID=257 Sprockets - Replace front and rear with chain if waited too long or if shark toothed Radiator Fluid Level - Check the overflow level and add as needed Clutch - http://www.cscmotorcycles.com/Articles.asp?ID=259 Clean fork stanchions Clean Shock Stanchion Clean motorcycle Polish plastics Clean windshield Check fork and shock for oil leaks Check for clutch slippage Check tires for wear and tear Clean and Lube chain if needed or wait 500 miles Scheduled Every time I fill up gas tank - 87 octane or better Lucas fuel treatment - .25oz per gallon Every 500 miles Clean and Lube the Chain Check Chain and Sprocket wear - 14x44T or 13Tx45T and 520 series chain Check Tire Pressure - OEM CST Tires=35psi rear / 33psi front cold, Shinko 244=33psi rear / 32psi front cold Check common nuts/bolts/screws for torque - http://www.chinariders.net/showthrea...111#post198111 / http://www.chinariders.net/showthread.php?t=14580 / https://www.cscmotorcycles.com/Articles.asp?ID=268 Every 2,000 miles Clean and Lubricate air filter - http://www.cscmotorcycles.com/Articles.asp?ID=266 Change the oil and oil filter. Clean the strainers. Use synthetic motorcycle oil - http://www.cscmotorcycles.com/Articles.asp?ID=266 Check clutch cable for fraying Lubricate clutch cable - http://www.cscmotorcycles.com/Articles.asp?ID=259 Check throttle cable for fraying Lubricate throttle cable Every 4,000 miles Adjust Chain - http://www.cscmotorcycles.com/Articles.asp?ID=257 Check Battery quality Check bolts - https://www.cscmotorcycles.com/Articles.asp?ID=268 Every 5,000 miles Rocker Valve Adjustment - http://www.cscmotorcycles.com/Articles.asp?ID=267 Replace fuel filter Every 10,000 miles Crankshaft Nut Maintenance - https://www.cscmotorcycles.com/Articles.asp?ID=312 Change Spark Plug Inspect Wheel Bearings - http://www.cscmotorcycles.com/Articles.asp?ID=259 Clean and Grease Rear Shock Linkage - http://www.cscmotorcycles.com/Articles.asp?ID=259 Fuel Filter Every 12,000 miles Steering Bearings Every 25,000 miles Replace Fork Oil - http://www.cscmotorcycles.com/Articles.asp?ID=259 Every 2 Years (9/29/2018) Replace radiator fluid - http://www.cscmotorcycles.com/Articles.asp?ID=260 Replace Brake Fluid - http://www.cscmotorcycles.com/Articles.asp?ID=256
2017 BMW F800GS Adventure |
11-18-2016, 01:20 PM | #3 |
Joe,
Thanks for putting all that info in one place. Excellent info, although I'm not quite ready to wait 5,000 miles on the valve clearance check. I've saved the list, and will print it out to post in my workshop. jb
11-18-2016, 06:45 PM | #5 |
Excellent maintenance schedule!
