Old 10-26-2016, 10:38 AM   #1
chuki   chuki is offline
Clutch problem
Hi everyone
I have this 125cc atv for my son and ist brand new.
https://www.amazon.de/gp/product/B01...?ie=UTF8&psc=1
I have filled in jaso ma2 10w40 oil bevore first start.
This atv will not move Forward, backward it have extrem power.
Look at this Videos
The clutch ist slipping, the lamellar are burned, but its brand new???
Its a centrifugal cluch
Its a automatic atv with Forward-neutraly-backward gear.
Any idea what the problem is?
Old 10-26-2016, 11:17 AM   #2
Adjuster's Avatar
Is it semi auto or full auto? Do you have to shift forward gears 1-2-3-4 at all? If semi auto the clutch is adjustable. If full auto the clutch is not adjustable.
Old 10-26-2016, 12:16 PM   #3
Try adjusting the clutch, which is found in the center of the cover; it is a stud with a nut. Follow Youtube instructions for an old Honda XR50.
Old 10-26-2016, 01:39 PM   #4
Hi everyone.
Its a full auto. I have also installed a new clutch.
Here another Video, is that normaly?
Old 10-26-2016, 01:56 PM   #5
Here any pics from this clutch
Old 10-27-2016, 11:32 AM   #6
Look at the center of the clutch cover; it has an adjusting screw and nut. I know that it is full auto, but it still requires adjustment.
Old 10-30-2016, 02:43 PM   #7
Dammn. Adjust at the front cover brings nothing.
What can i do
Old 11-02-2016, 07:19 AM   #8
Tao125f1   Tao125f1 is offline
Put smaller front sprocket on engine. If that does not help enough put bigger rear sprocket on.
Old 11-02-2016, 09:29 PM   #9
Clutch adjustment
Hello.... I hope you saw the ..adjust clutch on a Honda atv video........ you have to adjust it properly..... you say this is brand new,, and it was burned out when you took it off,,,,, is the old clutch the same thing??? it seems hard to believe the clutch works in reverse and not drive.. please tell us more.... changing the gtears will not help if no one played with the gear before... use 10-40 oil ... no systhetic oil... the gear shifter you show can move it into any gear... even in second gear it should move the bike... please tell us more..
ABIBABA ATV ETC
Old 11-02-2016, 09:37 PM   #10
youtube video
how to adjust Honda clutch
ABIBABA ATV ETC
Old 11-02-2016, 09:38 PM   #11
how to adjust a clutch
Please make this a sticky if possible,.... I would think lots would like this..
ABIBABA ATV ETC
Old 11-06-2016, 04:01 PM   #12
Hi
This ATV have F-N-R Full Auto.
Is the Gear down?
Search this Thread:
Advanced Search
Display Modes
