Old 10-27-2016, 11:34 PM   #1
ChondaChondaChonda   ChondaChondaChonda is offline
ChondaChondaChonda's Avatar
Odd build
So I have been riding my "hybrid" dirt bike for quite a few years. It's a 1993 CR125 chassis that has sported a reliable old Xr200 motor for many, many years... the registration stickers (mostly Idaho) are 1/4" thick and go back to the early 2000's maybe more.
The old XR finally gave up the ghost a few months ago. Blew a head gasket and wiped out the piston; still ran enough to get us home, albeit slowly. I wanted a "magic" button as I'm getting too old to kick flooded bikes on peaks over 8-9000' anymore.
Initially I was going to transplant a Crf230 motor, but dang if they aren't expensive little buggers!! $$$$ After looking for a good low cost motor and not finding one I decided to try a Zongshen 169FMM instead.
My research seems to indicate that these are pretty reliable motors, but my riding buddies are really REALLY not happy with my choice. May the Zong prove them wrong!!
Old 10-27-2016, 11:38 PM   #2
#1 reason i want to keep my old hybrid CR125/230 is that I have spent a ton of time and money dialing in the suspension over the last few years. Custom springs for my weight, rebuilt rear shock, lightweight oil in forks, etc. It rides just the way I want it for single track and some whooped out open desert sections.
The motor is partway bolted in and I actually twisted the wiring up and fired her up for the first time about an hour ago!! Sounds really good.
Old 10-27-2016, 11:53 PM   #3
She's ugly, but I love her.
Old 10-27-2016, 11:58 PM   #4
Here's a shot of the new motor almost bolted in. The two back mounts are on, but the top mount is a little different from the 200 so i will have to make a new one.
Name:  New motor 169FMM.jpg
Old 10-27-2016, 11:59 PM   #5
I pulled the cover off to try and figure out the wiring. Does anyone know the rated output of this style stator?
For the record:
Black/red stripe goes to Honda Black/red stripe (To CDI)
Blue/white stripe goes to Honda Blue/yellow stripe (To CDI)
Green/white stripe to Honda Green (Ground)
Yellow and Peach go to regulator, which is aftermarket 4 wire. Will not work with the little Crf230 regulator.
Name:  ZS169FMM wiring.JPG
The 6 wire plug going into the shifter for gear indication is useless to me so I just pulled it out.
Last edited by ChondaChondaChonda; 10-28-2016 at 09:04 PM. Reason: Add wiring details.
Old 10-28-2016, 12:01 AM   #6
169fmm
I've searched for hours on "169FMM" but there just isn't much good information out there. Most of what was found came from this forum. Big thanks to those who have posted!!
Here is my motor serial for anyone curious:
Name:  Engine numbers.jpg
Old 10-28-2016, 12:09 AM   #7
Odd build, odd guy, odd Introduction; I know...I know!
One issue that I do have is the sprocket alignment. Using a laser level to sight down the hub and sprocket it was pretty plain to see that the Zong motor's offset was about 8mm too far inboard. A new retaining method will be necessary. Any ideas?
Name:  Laser Sprockets.jpg
Name:  Laser Sprockets Front.jpg
Name:  Laser Sprockets 3.jpg
Old 10-28-2016, 12:27 AM   #8
Bruce's   Bruce's is offline
Any chance you could move the engine over to line up the sprockets ?
Old 10-28-2016, 12:31 AM   #9
Not too easily. The clearance from the carb to the frame is already tight, so it would make that a new issue.
Old 10-28-2016, 01:59 AM   #10
humanbeing's Avatar
Originally Posted by ChondaChondaChonda View Post
...anyone know the rated output of this style stator...
2 holes CB/ 88mm https://translate.google.com/transla...F67&edit-text=
Old 10-28-2016, 03:45 AM   #11
pete   pete is offline
pete's Avatar
start the motor... put in gear get the shaft turning...
hold a angle grinder with a cutting disc on the shaft
& put a new groove in it.....
LOL... well yer did ask...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 10-28-2016, 07:52 AM   #12
Welcome to here! Usually, the friends are trying to keep one away from an entire bike, not the engine. I have little doubt the engine WILL prove your friends wrong.
Old 10-28-2016, 09:02 AM   #13
Originally Posted by humanbeing View Post
Thank you!
So 90W is all. Ok. For future searchers:
Name:  Stator Output.JPG
Old 10-28-2016, 09:03 AM   #14
Smile
Hmmm...
Old 10-28-2016, 09:09 AM   #15
The backlash against this motor has been epic. My intent with this forum post is to document the issues that may or may not come up such as the sprocket alignment. If this motor ever leaves me stranded it will be a chorus of "We told ya' so!!".
Search this Thread:
Advanced Search
Display Modes
