top end rebuild how often?
hello guys i have a 2006 gy-2 style cg 200 with a zongshen 250 that i converted to a enduro style dirtbike. my question is with pure dirt use how often do i need to rebuild the motor with these chinese motors? I never really go above third gear but i spend alot of time at high rpm's. i was just gonna do the standard 150 hours that id do with a ktm or honda but was not sure if its more or less often since this does hold more oil then a dirt bike
thanks in advanced! |
#2 | |
the the air cooled zongshen 250 and it is a pushrod style
heres just a picture of the bike mid ride yesterday still runs great good compression as of now at least just pops alot since i cant find the exhaust gasket for the point that it connects to the motor
The pushrod engine is one of the longest lived little engines ever built. It was originally designed to operate in absolutely abysmal conditions. A good air cleaner, and thousand mile oil changes will make this engine run a very long time. So will valve clearance check-ups. If you don't have a speedometer, 1000 miles is about 30 hours at an average speed of thirty-five miles per hour. As long as the cylinder compression is good, the engine is good to go. The copper o-ring for the Honda 230 fits, and is much better than the original head pipe gasket that comes with these little hummers.
#6 | |
As ARH states, a dang long time , especially if maintained. It's not like the good-ol'-days where you had to do a bore, piston and rings every two season on your 2 stroke.
#8 | |
#9 | |
CG engines have a centrifugal oil filter under the clutch cover, attached to the crankshaft. It does a good job at trapping the fine particles. Quick and easy to clean once the clutch cover is removed.
The stock screen is identical to what is used in the Honda XR200 OHC motor. It works fine as long as it is cleaned every 10 hours or so.
Sometimes it's tight, but you can usually get the valve cover off without lowering the engine. Sometimes people will trim or grind away a bit of the valve cover fins to make valve cover removal possible / easier.
Thank you for that info. I didn't know that. I'll remember it, though.
#14 |
ok thanks for the info ill have to see about grinding it down next time a remove it because ive tried taking it off before while on the bike just didnt have the clearance hopefully doing that will let it slip off
#15 |
On some bikes the valve cover will clear the frame if the rocker arms are in a certain position. If it almost comes out, try rotating the crankshaft and see if there is a spot where you can wiggle it out.
