Old 03-16-2016, 11:12 PM   #16
mjstef   mjstef is offline
Originally Posted by humanbeing View Post
Gear indicator is found in most stock vertical chonda engine.
Most "变速鼓" https://huabmp.taobao.com/search.htm...E4%CB%D9%B9%C4 had that Brass tab / Some model lacks "档显" (the wiring) https://huabmp.taobao.com/search.htm...d=%B5%B5%CF%D4 ONLY
Are you saying that a peace for the gear indicator needs to be installed? I'm not quite understanding you....
Old 03-16-2016, 11:33 PM   #17
humanbeing's Avatar
1. "Brass tab" in shift drum
2. position s/w "下" (low) 档显 | Had many style , different holes...
3. wiring "上"(up) 档显 to display unit...
Most vertical chonda had [1&2] from factory...
Since i don't see it in person...i don't know Hawk lacks ALL, 2&3 OR 3 ...
Old 03-17-2016, 03:50 AM   #18
TXDSRIDER   TXDSRIDER is offline
TXDSRIDER's Avatar
If most of the features work when you test it I'll take one too.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
1987 Honda TRX 250R X2 one stock one modified
2002 Buell Blast
2001 Buell X1 Lightning
2000 Kawasaki ZR7
Old 03-17-2016, 08:11 AM   #19
farmbath   farmbath is offline
I would be interested too.
Old 03-17-2016, 08:56 AM   #20
Hancadam   Hancadam is offline
If it works out, I'll buy one as well.
Old 03-17-2016, 09:03 AM   #21
kohburn   kohburn is offline
kohburn's Avatar
if that's what the indicator is set up for then we can expect to leave it off.
I'm not really concerned about it. it would be nice but much less important to me than a tachometer.
-whatever you do, just be awesome.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 03-17-2016, 09:05 AM   #22
kohburn's Avatar
one of the advantages of switching to an electronic speed sensor is that even if its not adjustable we can install a speedo healer like spud and adjust it for different tire sizes.
- 2016 CSC TT250
Old 03-18-2016, 07:30 AM   #23
kohburn's Avatar
this is how a universal gear indicator can be done using only electronic inputs with no gear switch
http://www.ebay.com/itm/201113588938...%3AMEBIDX%3AIT
- 2016 CSC TT250
Old 03-18-2016, 08:46 AM   #24
Ron B   Ron B is offline
Ron B's Avatar
so if im at red light in 3rd gear with the clutch pulled in its going to say im in 1st or neutral because of the speed? id rather do without it
Old 03-18-2016, 09:57 AM   #25
kohburn's Avatar
no, it would show the last gear measured. neutral is only indicated by the neutral switch, and to show first the rpm and speed need to match what its been programmed to see for that.
there is a wire that gets connected to turn on its learning mode.
but if this one is designed to match the Honda style gearbox switch then its a different animal and would be useless for us.
I don't really care either way - the tach and digital speedo is what I want.
- 2016 CSC TT250
Old 03-20-2016, 08:41 PM   #26
midlifemx5   midlifemx5 is offline
I would be interested in a pair of them.
Old 03-21-2016, 08:49 AM   #27
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
Put me on the list as well, please.
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 03-21-2016, 11:54 AM   #28
Tranberg   Tranberg is offline
What I beleive Humanbeing is saying is that you just need to buy the gear position sensor, and maybe the brass pointer which rotates with the shift drum.
I can't find it for the CG-clone engines, though.
I only have hands-on experience with the horizontal cylinder Honda clone engines, where the pit bikes don't use a gear indicator, but the crate engines come wit one, so you either leave it unconnected or buy a blanking plug to replace it.
A spare gear indicator costs $5 delivered form Aliexpress.com in China.
Old 03-27-2016, 09:12 AM   #29
sevndaythry   sevndaythry is offline
i too would probably buy one, maybe even two
Check out my Hawk 250 Motovlog Channel
https://www.youtube.com/channel/UCUU...JoVrsuhnV-7Zkw
Old 03-27-2016, 11:03 AM   #30
superchevy   superchevy is offline
Just watched some of your Videos. Really liked them and thought they would help me decide to get a Hawk 250. So far im really impressed with this Chinese Motorcycle. Seen that yours runs really well. Did it run that good straight out of the box after you put it togather.
Search this Thread:
Advanced Search
Display Modes
