Closed Thread
Old 11-18-2015, 02:43 PM   #1
Confirmed Torque Specifications: Zongshen RX3
This thread contains a list of confirmed torque specifications for critical bolts of the Zongshen RX3 motorcycle. This thread is closed. Please contribute your confirmed torque specifications at the following thread. Thank you.
http://www.chinariders.net/showthread.php?t=15535
Lower Shock Linkage
All bolts for the rocker/knuckle/arm, except the lower shock bolt: 38 foot-pounds
All bolts for the link/dogbone: 38 foot-pounds
Lower Shock Bolt: 33 foot-pounds
Upper Shock Bolt
33 foot-pounds
Swingarm Bolt
54 foot-pounds
Old 11-18-2015, 07:15 PM   #2
Rear Axle Bolt
50 foot-pounds
Old 11-19-2015, 03:19 AM   #3
Torque Specifications Taken from the AJP PR5 Owner's Manual
Oil Drain Plug, Oil Screen Plugs, Oil Filter Cover
Oil Drain Plug: 18.5 foot pounds (25 Nm)
Oil Screen Plugs: 18.5 foot pounds (25 Nm)
Oil Filter Cover Bolts: 6 foot pounds (8 Nm)
Cylinder Head
Cylinder Bolts: 28 foot pounds (38 Nm)
Triple Head Clamps
Upper Triple Clamp: 15 foot pounds (20 Nm)
Lower Triple Clamp: 9 foot pounds (12 Nm)
Old 11-19-2015, 03:46 AM   #4
Torque Specifications Taken from the Gas Gas EC Cami 250 Owner's Manual
Front Brake Caliper Bolt: 18 foot pounds (25 Nm)
Engine Mount Bolts: 26 foot pounds (36 Nm)
Crankcase Bolt: 7 foot-pounds (10 Nm)
General Torque Specifications
M4 Nuts & Bolts: 26 inch-pounds (3 Nm)
M5 Nuts & Bolts: 53 inch-pounds (6 Nm)
M6 Nuts & Bolts: 10 foot-pounds (7 Nm)
M8 Nuts & Bolts: 18 foot-pounds (25 Nm)
M10 Nuts & Bolts: 33 foot-pounds (45 Nm)
Old 11-19-2015, 04:04 AM   #5
Please note, the torques in this diagram are specified in newton-meters. The following link will convert newton-meters to foot-pounds.
http://www.convertunits.com/from/N+m/to/ft+lb
Closed Thread
Search this Thread:
Advanced Search
Display Modes
