#46 |
If you have time, please post photos of your installation.
#47 | |
Banned
Aimed properly they actually throw usable light. Not a flood |
#48 |
I installed the Tractor Supply Traveller auxiliary lights discovered by Huck369.
![]() ![]() http://www.chinariders.net/showthread.php?t=15437 ![]() ![]()
#49 |
Photos of eBay aux lights
Here are photos of my aux lights purchased from an ebay seller. Simple installation and good wide stance. I kind of like the military "ray gun" look, though the surrounding guards are just painted sheet metal. They are vulnerable to tip overs in this position but they are only $35.
Again, I ditched the clamps, and used the bolt that secures the upper and lower guards. I needed a longer 8mm bolt a 1/2 spacer, and ran the bolt through the inner sheet metal "guard" for the lamp. The lights can be swiveled up or down, and the lamps can be adjusted left or right. They produce a focused spot pattern. One failed but the ebay seller sent me a replacement and I have my fingers crossed that they will last. |
#50 |
Looks great, NoVA Rider! Between you, Spud and everyone else... I'm having Auxiliary Light Envy!
![]() I saw a fellow RX3 rider's 30W lights over the weekend. It was daylight, and they were indeed bright. But I'm tempted to give those a try... they're more spendy, but I'm thinking those lights would be useful for both the Urban Jungle, and for remote trails if I ride in the early AM hours or get caught in the dusk hours. I need to save up a few shekels though... been spending on a another project on the RX3. ![]() |
#51 |
I found these lights on Amazon, and installed them yesterday:
http://www.amazon.com/gp/product/B00...ilpage_o01_s01 For 50 bucks with free Prime shipping, not a bad deal. I like the fact that they came equipped with weatherproof (resistant!) plugs. I also purchased this wiring harness from an eBay seller in England: http://www.ebay.com/itm/191533392034...%3AMEBIDX%3AIT I know my limitations, and creating neat wiring is an area in which I am limited ![]() I purchased the 1" bar mounts from CSC, and mounted the lights inside the lower crash bars. http://www.cscmotorcycles.com/1-BAR-...p/csc-1011.htm I wanted a large triangle of lights for daytime visibility, so I was a little concerned about mounting them inside the crash bars. But after hooking these things up and turning them on, I'll probably be summoning aliens-they're plenty bright! Plus, I can always move them if I want. I also stole a tutorial from a website called Canyon Chasers on how to build a power distribution block for a motorcycle: http://www.canyonchasers.net/shop/generic/relay.php I couldn't find the sort of block the author used, but I did find this device that's apparently used for car stereo amplifiers: http://www.amazon.com/gp/product/B00...ilpage_o02_s00 Once I had the power distribution block wired together (it stows nicely under the passenger seat), I hooked up my previously-installed heated grips to make sure it worked. It did. So I hooked up my new wiring harness, mounted the lights, and they fired right up, too. By the way, I have the power distribution block powered with a relay that's attached to the Auxiliary 1 switch. So I can turn the switch to the Aux 1 position, and then have power for my heated grips or lights or both, and each is switched on and off separately. Here's what they look like mounted to the crash bar: Here's "on:" Now I just have to wait for my new O2 sensor to arrive from CSC, and the current round of snow to melt, and I can go try them out!
2009 TW200 (first bike ever, sold it!);2015 RX3 Cyclone in blue (first "big kid" bike ![]() |
#52 |
Nice job
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp, |
#53 | |
#54 | |
#55 |
[QUOTE=SpudRider;197416]That is a clean installation.
![]() ![]() Thanks for the kind words...you notice I didn't post any pics of the underside of the install! I think I'll reroute cables when I have the gas tank off when I do the valve adjustment, and then I might reveal what it looks like behind closed doors!
#56 |
We will await further photos after you pull the fuel tank.
![]() Please tell me more about the power distribution block. ![]() One block connects to 12V+, and the other block connects to ground. You have four outputs for each input. Where do you attach the wires?
#57 | |
The other nice feature of this block is that the two terminal portions (the metal parts) are covered with removable acrylic covers, which keeps any inadvertent short-circuits from happening. All in all, once I figured out how to keep the smaller wires secure, it's a nice, simple piece of equipment. By the way, this particular one measures about 2 3/8 inches square, if anyone was wondering.
#58 |
Thanks for posting the detailed explanation.
#59 |
If you live anywhere near any kind of boating/marine supply store they are the best place to purchase any kind of electrical connection type components. Boats have tons of electrical accessories needing all types of components and everything is marine rated at a minimum water resistant all the way up to salt waterproof. The connections above are called busbars and come in every imaginable shape and size. Marine supply stores sell every shape and size.
