Old 06-30-2015, 08:23 PM   #1
Scrami71   Scrami71 is offline
Head Scratching Crankcase Breather Tube
Hi all. Just wanted to know if any of you have experienced your crankcase breather tube being partially full of oily gas. Came back from a 180 mile run today and the crankcase breather tube was between a quarter to half full of gas that looked and felt like it had some oil mixed in with it. Pics for reference to the tube I am talking about
Scrami71
RX3
Triumph Speed Triple
http://tarmacstrails.net/
Old 06-30-2015, 08:33 PM   #2
Adjuster's Avatar
Well that's not right at all.
Is there any moisture in your oil?
Are you absolutely positive that's not your carburetor drain tube?
Old 06-30-2015, 08:34 PM   #3
Adjuster's Avatar
What is that tube behind the kickstand? I believe that should be your crankcase vent tube.
Old 07-01-2015, 02:31 AM   #4
rjmorel   rjmorel is offline
rjmorel's Avatar
see my post #13 in thread above this one. No worries, rj
http://www.chinariders.net/showthread.php?t=14697
Old 07-01-2015, 02:47 AM   #5
That tube collects the oil from the crankcase vent. That tube should not have any fuel in it. The tube behind the swingarm bolt drains excess fuel which collects outside the gas cap.
You must be getting fuel in your engine oil, which might be caused by a bad fuel injector. I suggest you promptly contact CSC and tell them of this problem.
Old 07-01-2015, 12:17 PM   #6
Indeed. Does the crankcase smell of fuel?
Old 07-01-2015, 03:41 PM   #7
katflap   katflap is offline
katflap's Avatar
I have had a similar issue, the liquid was all but clear and consisted of a water/ fuel mix.
The concentration of fuel in this liquid was enough to chemically melt the black Oil/water separator.
I have recently replaced the oil/water separator and fitted a new injector.
Its too early to say whether it has cured this problem and also an issue I have been having of fuel contamination causing the oil level to rise.
These problems seemed to be at their worst during the colder months of the year, so it might not be until winter that I will truly know
Update
** oil level rising might not be an issue after all, check out CSC blog on checking your oil level **
Search this Thread:
Advanced Search
Display Modes
