06-10-2015, 03:21 PM | #1 |
Turn signals
mine stopped working completely, any ideas on where to check first ?
I tried the bulbs, it's not them... |
06-10-2015, 03:32 PM | #2 |
Check the fuse, flasher, and connections.
06-11-2015, 08:42 AM | #3 |
Where might the fuse box, and what's a flasher ?
06-11-2015, 09:10 AM | #4 |
WYSiWYG http://item.taobao.com/item.htm?id=36546726632
--- Fuse http://item.taobao.com/item.htm?id=39518112538 is near the battery --- #4 connector Most stock flasher http://item.taobao.com/item.htm?id=38700497132 are colored in black
06-11-2015, 01:40 PM | #5 |
Not sure on your bike, but it is common practice to hide all this stuff under the seat next or near to the battery. Sometimes under the fuel tank, but not always.
So, remove the seat and find the battery. Hopefully near it you will see an in-line fuse or a set of fuses in a little holder. The "flasher" will be the relay that makes your indicators go on and off. It is usually about 1 inch square or 1 inch round tube. Vibration can cause fuses to blow or relays to unseat themselves, so as Spudrider suggested, gently push and pull connections to make sure they are seated properly. Go to a supermarket and buy a cheap voltmeter / test meter. A few dollars. This can be used to check that 12v is getting to the bulb or as a tester to see if fuses are blown or not. Can save you loads of time troubleshooting silly issues. Good luck! Jeff
- - - - - - - - - - - - - - - - - - - - - - - Riding bikes for over 40 years Honda C50 / SS50 / CB125 / CB250 Velocettes (various) Piaggio's / Honda's / Yamaha's Raptor . . . . the List Goes On . . . . |
06-11-2015, 01:46 PM | #6 |
Yes, you definitely need a digital multimeter if you are going to troubleshoot electrical problems on your motorcycle. This meter from Harbor Freight (HF) is sufficient for most electrical work on your bike.
http://www.harborfreight.com/7-funct...ter-90899.html You can frequently find a coupon from HF which will get you that meter for free.
06-11-2015, 04:03 PM | #7 |
Love my Harbor Freight meter. It has fixed electrical on cars, trucks, boats and motorcycles. I paid full price for mine. $3.99 I believe. LOL
06-11-2015, 06:22 PM | #8 | |
06-11-2015, 07:43 PM | #9 | |
Edit: It has to be something with the connections up front right now no matter side I set the switch all 4 flash |
06-11-2015, 08:41 PM | #10 |
Most signal system in vertical chonda are similar to
06-11-2015, 09:37 PM | #11 |
I just can't figure it out. I know it's the pins in the front I think but the back is connected properly and when o disconnect the front and hit the switch both side still flash, do I have this thing in hazard mode???!!
06-11-2015, 10:11 PM | #12 | |
--- Does u clicked some mystery switch that's for the "hazard"? If not, left (orange) & right (sky blue) may jammed together somewhere accidentally (PITA to find it 1 by 1 ) .
06-11-2015, 10:13 PM | #13 |
Shit... I did upgrade them to leds I read some where that I need to change the dash indicator bulb or something... Halp ?
06-11-2015, 10:27 PM | #14 |
http://www.chinariders.net/showthread.php?t=13572
Remove the dash indicator bulb or use "diode kit". Those parts can easily found via some F***ed PCB if had soldering iron ...
06-11-2015, 10:29 PM | #15 | |
Edit: cut out the indicator lights works now, thx! Last edited by Dionili; 06-11-2015 at 11:12 PM. |
