Old 05-15-2015, 08:55 PM   #3511
Originally Posted by woodlandsprite View Post
Well Poop. It looks like I might be testing the dime/washer spring trick myself because it seems CSC ran out of center stands and did not put one on my bike.
Also get to figure out the whole dash accessory install too since those also ran out and my bike shipped without it installed. *sigh*
If you use a lot of dimes/washers, you won't have a problem with the centerstand spring.
Regarding the power outlet installation, CSC says you don't have to remove the windshield. I installed the cigarette lighter outlet with the windshield installed, then removed the windshield for the installation of the USB outlet. I suggest you do yourself a favor, and remove the windshield before you start this project. In my opinion, you will use far less time, and suffer far less frustration, if you remove the windshield first.
Old 05-15-2015, 09:05 PM   #3512
Originally Posted by rjmorel View Post
Jaume, don't forget to run the inner tube valve securing nut up away from rim tight onto the plastic cap. This way if your tire slips on the rim ,it won't rip out the valve stem and you can see if the tire slips on rim , as the valve stem will be bent over. rj
That is excellent advice.
All Honda dirt bikes come equipped with rubber grommets which support the valve stem, and keep dirt out of the valve stem hole. The rubber grommets replace the valve stem nut, and allow the valve stem to move as the inner tube shifts.
If you don't have a Honda dirt bike, you can buy the Tusk Rubber Valve Support/Seal kit for $1.99 from Rocky Mountain ATV/MC.
https://www.rockymountainatvmc.com/p...e-Support-Seal
I have these rubber grommets installed on the valve stems of all my motorcycles. I love them, and highly recommend them.
Old 05-15-2015, 09:10 PM   #3513
Here are two, excellent, tire changing videos which show the removal, and installation of the Honda rubber grommets on the valve stem.
Old 05-15-2015, 09:11 PM   #3514
Old 05-15-2015, 10:54 PM   #3515
AZRider   AZRider is offline
Couldn't agree more. This is where an extra 3 minutes of dis-assembly will save 15 minutes in frustration.
George
2016 CanAm Spyder F3-L
Old 05-16-2015, 04:12 AM   #3516
pete   pete is offline
pete's Avatar
How about this one.... in the same vain as the RX3...
Chinese or componet bike with a French lable.... not sure if it's all chinese...
http://www.mash-motors.fr/moto-mash-...ure-400cc.html
Near the bottom theres a pic of a Marsh road bike with the same motor...
Anyone seen the motor before ?
http://www.google.co.nz/url?sa=i&rct...31851062296429
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 05-16-2015, 12:04 PM   #3517
I think that is the Shineray X5 motorcycle, Pete.
http://www.chinariders.net/showthread.php?t=12001
Old 05-16-2015, 02:01 PM   #3518
Well Poop.
Language! This is a family forum.
Old 05-16-2015, 02:37 PM   #3519
Forum member JTHSpace found a small, reasonably priced, speedometer corrector which will work for the Zongshen RX3. If anyone is interested in a group buy of this unit, please join us at the following thread.
http://www.chinariders.net/showthrea...913#post184913
Old 05-16-2015, 05:44 PM   #3520
pete's Avatar
Now thats a chinese bike I could own.....
But the Shineray 200 I had... well it fell apart under me..
Just a pitty Honda don't import there XR400 based ADV bike here...
Honda XRE400 Falcon...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 05-16-2015, 06:38 PM   #3521
oldqwerty   oldqwerty is offline
If the Cyclone takes off, maybe Honda will see the light. The price premium for that extra 150cc will be pretty stiff, though.
"Thou shall not Zong" is not a commandment.
Old 05-16-2015, 06:47 PM   #3522
I think the Shineray X5 has similar problems with quality control, Pete. Isn't the XRE 400 Falcon manufactured in Brazil?
Old 05-16-2015, 06:48 PM   #3523
There's no doubt about that. In addition, the Honda bike won't have all the standard features of the Zongshen RX3.
Old 05-16-2015, 08:00 PM   #3524
pete's Avatar
yes it is.....
I had a 05 XR250 Tornado was also made in Brazil... dam nice bike
should have kept it... they use the DOHC/air cooled / six speed CBR250 motor
so very nice to ride on the road.. Honda turned it into the XRE300 with the
CBR300 air cooled motor...
any way.... watching to see how the RX3 goes.... Maybe a future investment....
Tornado
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 05-16-2015, 08:11 PM   #3525
Thanks for posting the beautiful photograph from New Zealand.
I agree; you should have kept that motorcycle.
Search this Thread:
Advanced Search
Display Modes
