05-09-2015, 12:06 AM | #46 |
If you don't change anything other than the size of the rear sprocket, you will need to remove 4 links from the drive chain.
05-09-2015, 12:04 PM | #47 | |
The shifter seal is likely to be the same as a Honda XR200, but you can likely just take the numbers off of the seal and get a replacement at a local bearing shop.
05-09-2015, 07:15 PM | #48 | |
(I opened up the intake holes about double the original size) I operate primarily at 5000 - 8000 ft above sea level, where would you recommend I start with the jetting, with these conditions in mind?_ P.S. this is a 229cc engine Last edited by midlifemx5; 05-09-2015 at 07:26 PM. Reason: additional info |
05-09-2015, 07:24 PM | #49 |
Thanks Weld, upon taking a really good hard look at the oil leak today I found the oil level to be about a 1/2 quart too high, after correcting this the oil leak seems to have been eliminated. Ill keep an eye on it, and report back. (I feel stupid)
05-09-2015, 09:07 PM | #50 | |
05-10-2015, 11:03 AM | #51 | |
Even if the seal doesn't heal itself, it's not a big deal to replace.
05-10-2015, 11:05 AM | #52 | |
I'd start with a 115 main and a 30 slow. If it won't start despite adjusting the pilot mixture screw, go to a 27.5 slow.
05-10-2015, 11:06 AM | #53 |
I'll accept enthusiast, but I'm no expert.
05-10-2015, 04:46 PM | #54 |
Thanks for the starting point. I'll put in an order for some jets to get started with. BTW I see that there are 2 different styles of slow (pilot jets) for the vm series carb which ones does the carb in your link take?
05-10-2015, 05:48 PM | #55 |
Maybe a better question is what series# is this Carburetor, I'm pretty sure it's a VM, but what is the sub series # I cant really tell for sure from your comparison photos which type of slow jet to order. Sorry for all the questions you have probably had to answer before
05-11-2015, 12:49 AM | #56 |
IIRC, the China 30mm Mikuni takes a VM28 / 486 style slow jet.
05-11-2015, 12:53 AM | #57 |
Please don't hesitate to ask questions! I love hanging out in this shop, and I'm happy to contribute whatever I can. Thanks for joining us.
05-11-2015, 01:00 PM | #58 |
Thanks so much the help is much appreciated!
05-15-2015, 11:11 PM | #59 |
I got the carb and jets today! I don't think I will get them installed tomorrow but I will post a report when I do.
05-16-2015, 01:48 PM | #60 |
Awesome! I hope it works out well for you.
