#3001 | |
According to the pic, the upper spring mount seems to be a flat bracket that is retained by an 8mm bolt.
#3002 |
Weld,
JimJr21 gave us a nice report regarding the RX3 muffler's construction. ![]()
#3003 | |
#3004 | |
#3005 |
Definitely. I'd need to examine it, before I could establish a game plan.
#3006 |
Hello all, I just buy this bike two days ago, white one. AWESOME!
It's hard to say I'm not enjoying as much I would like. When I drive, as soons as I start the engine, by the right side of the motor I get a lot ot "wind". Later when driving like 20 minutes or less it starts to get warm "this wind" or "vapor". My right leg gets really warm. All this "vapor" arrives to the right leg of the passenger too. I guess something is wrong. Today I notice. I have to vents in each side. The left one actives but not too much, and not too warm. The right one, is very soon to actived it and gets "warm air". Is this normal? Why one side is warmer than the other? Shouldn't be equal at both sides? I'm in my first 87 KM. I have not past 60 kmph on 4th gear. |
#3007 |
I just received my RX3 motorcycle. Therefore, until I have a chance to ride my new bike for a few miles, I won't know if your experience is normal.
However, the hot coolant from the engine first travels to the right radiator, then moves to the left radiator, before returning to the engine. Therefore, in your case, I suspect the right radiator is venting more heat than the left radiator.
#3008 | |
You mention getting a lot of "wind " on the right side as soon as you start it. Is the right side radiator fan coming on as soon as you start it? As for the "vapor" are you loosing coolant from a loose radiator cap or hose clamp ? Just thinking out loud here. Let us know what you find. rj |
#3009 | |
I mean why the right radiator is venting more heat than the left one? Anyone else is having this situation? I would like a explanation so I can understand this ![]() Even with this, great bike. |
#3010 |
Spuds what color did you get? What trucking outfit did yours come on? thanks, rj
#3011 | |
![]() Since the hot coolant first enters the right radiator, a greater amount of heat might be removed in the right radiator before the coolant moves to the left radiator.
#3012 | |
As soon as I start, no. The first time was like that. I have checked right now and is engine ON but no vents working, which is OK. When I say vapor, I didn't mean like smoke or something visible. I was refering like a blowing (vent, radiator) My question is why the right vent is warmer and venting more than the left one? Today I had it checked in the Zongshen service center. And they found nothing. |
#3013 | |
![]() ![]() My bike was shipped via Reddaway Trucking. http://www.reddawayregional.com/ God willing, I plan to pick up the bike at the loading dock, and assemble it tomorrow morning. With any luck, I should have insurance and a license plate shortly thereafter. If all goes well, I plan to go for a ride, and take some photographs. ![]() ![]()
#3014 | |
#3015 | |
Here are reasons why. Immediate wind with heat. Radiators take a while to heat up. Instant heat leads to exhaust. Right side has three possible locations that would have an easy leak. 1) header to muffler joint. There is a fiber material clamping and sealing the two steel pieces. Easy to damage (or be missing) 2) O2 sensor. Loose, missing, cracked weld 3) Header to head. Loose clamp or damaged or missing gasket. Outlet is faced to right side and wind speed would blow to right side. Having ridden in 40-70F temps so far 1 and 2 up there is no noticeable heat on right leg for either of us. Wearing jeans or work pants. Good luck in finding the source of heat.
Currently In the garage in various states of running (or not) order 2015 Rx-3 super speedy blue 2003 BMW F650GS 2001 H-D V-Rod 1999 Ducati 750SS 1997 Yamaha Riva 1995 KTM 250 1970 Honda CB350 1952 Ariel Square four |
