#31 |
Measure the battery with the engine off, and then again when running. Voltage should jump to the 13 or 14 volt range when running.
#32 |
This http://www.ebay.com/itm/261684410983 is very useful.
#33 |
I think it may just be a bad battery connection. I'll be looking at it tonight.
#34 |
A good ground is mandatory. Don't just run the ground wire from the battery to the motor; branch off to the frame as well. Larger wire is better.
#35 |
The battery connections were rusty still.
I still need to ride it around with the lights on and check but the voltage is there. |
#36 |
Does anyone know what tach and speedo cables I can use on this?
#37 |
That insurment is from Suzuki
One of these might work if u knows both end's shape & the length. http://weidong360.taobao.com/search....ce=&highPrice= http://weidong360.taobao.com/search....ageNo=1#anchor
#38 |
Ya I still can't figure out that website.
#39 |
I've got a KLR cable and a honda cable inbound.
We'll see what happens. |
#40 |
Neither cable are correct. Le Sigh.
I ordered a different one from one of the vendors that had one listed. So another wait..... ![]() Would one of you guys that have the china parts ordering thing figured out be willing to broker something for me? I paypal you, you order the part for me, that kind of thing? |
#41 |
Honestly, it's not difficult. We would be happy to walk you through it.
#42 |
That'd work.
i suppose i could get an aftermarket dash for it, but seems like what's there should work fine. |
#43 |
So 3 cables down now.
The one from the new vendor here arrived pretty quick. Just isn't the right one for this thing. |
#44 |
Still open to input for cables.
Put a front tube in it, and a box on the back. ![]() Saddlebags at some point. |
#45 |
Another question.......rear shock. This one is......terrible. Porpoises bad. Any input for where to search for a replacement?
