Old 06-06-2014, 06:15 PM   #31
pete   pete is offline
pete's Avatar
I just can't help myself...
If theres a bike in the shed i just have to play with it...
Ordered a set of USD forks & a internal rotor ignition unit
for Calebs bike...
I like this bike... parts are just so dam cheap.... even a
alloy frame is worth almost nothing...
Still need a rear shock.... might see if I can mod the mounts
to take a jap shock... as yer just don't know if these so called
trick pit bike shocks are any good....
It must be hard for him to ride as its just riding on springs no damping
in either end...
Pete
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-07-2014, 01:22 AM   #32
I'm sure that Caleb is made of rubber, like most fearless boys his age.
Looking forward to the USD fork install.
Old 06-19-2014, 04:30 AM   #33
pete's Avatar
the forks arrived...
How much oil do the pit bike usd forks take ?... anyone have a idea...
damping a bit fast on the return stroke..
like to put a thicker oil in...
also have a internal rotor ignition unit to go in..
I got the chain de-railing sorted... nylon guide discs each side
of the rear sprocket... not tossed the chain since I put them on...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 06-19-2014, 11:26 AM   #34
No idea. How much oil came out?
Old 06-20-2014, 02:39 AM   #35
pete's Avatar
not a drop yet....
i will see...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 06-28-2014, 06:38 AM   #36
pete's Avatar
Doh!
well I just cut the frame into a couple of bits...
going to lengthen the wheel base 75mm...
Also thinking of cutting it just above the main engine mount
to lower the motor & get the foot pegs 50mm lower aswell
as put the swing arm on less angle...
Basicly make the whole bike a bit bigger...
pete.
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-02-2014, 12:48 AM   #37
You're re-engineering the whole bike!
Old 07-02-2014, 03:11 AM   #38
pete's Avatar
yer I just have to play with things... can't help myself...
Have only gone for 55mm longer other wise the steering head would be
way out in front of the tank... look really silly..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-13-2014, 01:40 AM   #39
pete's Avatar
all back togeather... and the wheels are now in line...
should be a lot better to ride... they were almost half a tire
out of alinement.. front was 35/40mm to the left of the rear..
Lifan motors are good... the rest of the bike is PURE crap...
How the little shits can sleep at night putting crap like
this on the market I will never know..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 07-13-2014, 02:44 AM   #40
I agree, but the low quality is reflected in the price. There's no way you could get close to that price for a new Honda.
As you say, the motors are good, and guys like us fix everything else.
Got pics?
Old 07-23-2014, 11:06 AM   #41
Pete, do you have a link to the USD forks you ordered?
Old 10-11-2014, 04:03 AM   #42
pete's Avatar
Oil....
just changed the oil with Motul 5100 "Yamalube"
the gear box has been stiff/crunchy & very hard to
find neutral...
After 5 mins with the Motul in it... Box is smoother
& neutral is easy to find... Very easy...
Theres oil & theres oil...
been useing Mobil 2000 , 20/40
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 10-13-2014, 07:03 PM   #43
I used Motul in an old XR250, and it shifted well after that. The problem with it is the cost.
Old 10-14-2014, 01:41 AM   #44
pete's Avatar
Had a look at a nice 09 Kawasaki KLX140 today..
might be Caleb's Xmas pressie...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 10-14-2014, 07:15 PM   #45
Nice! He practiced on a China bike, and he'll be better equipped for a Kawi 140. Please let us know if you pull the trigger on it.
Search this Thread:
Advanced Search
Display Modes
