Zongshen RX3 (ZS250GY-3): Delphi Multec EFI
The Zongshen RX3 employs Delphi Multec Electronic Fuel Injection, which is documented at the Delphi website.
http://www.delphi.com/manufacturers/...wertrain/small http://www.delphi.com/docs/default-s...f.pdf?sfvrsn=0 ![]() Single cylinder motorcycles, such as the Zongshen RX3, employ a system using the MT05 engine control module (ECM). http://www.delphi.com/manufacturers/...owertrain/mt05 http://www.delphi.com/docs/default-s...f.pdf?sfvrsn=0 This ECM receives information from a number of sensors. Zongshen provides the crank sensor, which is located inside the Zongshen NC250 engine. The engine temperature sensor measures coolant temperature, and is located in the thrermostat housing under the fuel tank. The oxygen sensor is attached to a bung on the exhaust header. http://www.delphi.com/manufacturers/...in/mini_swh_ox http://www.delphi.com/docs/default-s...f.pdf?sfvrsn=0 The manifold absolute pressure (MAP) sensor, manifold air temperature (MAT) sensor, and fuel injector are attached to the intake manifold. The throttle position sensor is incorporated in the Delphi throttle body. http://www.delphi.com/manufacturers/...rain/etc_tb_sm http://www.delphi.com/docs/default-s...f.pdf?sfvrsn=0 A fuel pump, which provides pressurized fuel to the fuel injector, is located inside the fuel tank. http://www.delphi.com/manufacturers/...rain/sm_eng_fm http://www.delphi.com/docs/default-s...f.pdf?sfvrsn=0
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 11-24-2015 at 02:16 AM. |
The Delphi Small Engine EMS Service Manual is located at the following link.
http://www.huntermotorcycles.com.au/...l%20Manual.pdf
Many Harley Davidson motorcycle employ the Delphi Multec EFI system. The following link describes how Delphi EFI systems work in the multi-cylinder HD engines.
http://www.nightrider.com/biketech/m...asics.htm#null
Many Yamaha motorcycles also employ electonic fuel injection. Although the Yamaha EFI systems are different from the Zongshen EFI system, one can learn many troubleshooting techniques by watching the following Yamaha videos.
Here are a several videos showing how to clean a fuel injector.
I'm geeking out over this stuff.
I was surprised (and impressed) to learn that Delphi offers a stepping motor throttle body, rather than a throttle cable. That would create drive by wire that is so common in cars now. I don't want that level of complexity on my bike, but it's cool nonetheless.
#8 | |
Thank you for your input, Racer.
The Multec MT05 webpage indicates this ECM employs idle air control (IAC), which undoubtedly utilizes the stepper motor.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 01-09-2015 at 09:39 PM. |
The Delphi webpage for the Multec MT05 contains this information.
Serial Communication feature flexibility: Controller Area Network (CAN) or KW2000 http://www.delphi.com/manufacturers/...owertrain/mt05
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![]() 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 01-09-2015 at 09:41 PM. |
I just found a web source which indicates you can use an OBD2 reader for all late model cars to communicate with the Delphi MT05 ECM.
![]() ![]() In the meanwhile, here are several links to OBD2 and CAN scanners. You can get one from China for $16.25, delivered. ![]() http://www.nationaltoolwarehouse.com...IuJxoCATfw_wcB http://www.ebay.com/itm/Autel-MS300-...p2054897.l4275 http://www.harborfreight.com/can-obd...0693-html.html Apparently, you can also borrow an SERT scanner, and export the data to free graphing software. ![]()
#13 |
Perhaps we can use this $9 cable to connect a computer directly to the Multec MT05 ECM.
![]() http://www.ebay.com/itm/VAG-COM-KKL-...p2054897.l4275 ![]()
#14 | |
#15 | |
