09-17-2014, 03:11 PM | #31 | |
Hi Migu, I got the CDI from OOracing in the UK (£50). The CDI advances the timings by 5 degrees, which apparently is alot (I asked someone). The jets should arrive for my bike tomorrow and I'll put them in and tell you the difference. I installed the O2 sensor so I could precisely calibrate the tune from the Carb, as the jets were all wrongly numbered and I was getting very confused...... I looked at a Mikuni Carb too, but it didn't look the same so I left it alone. Maybe someone else can tell us if they fitted it. |
09-18-2014, 12:23 AM | #32 | |
09-18-2014, 12:24 AM | #33 | |
09-18-2014, 04:05 AM | #34 |
I'm not really sure, because the wire is short from the sensor, then goes into a box, changes gauge and onto another wire that's like 6 foot long. I guess that's the wire you want to change to like 3 foot or something - or splice it, but then you loose all of the pretty cabling they did for you.
I here they sell a smaller model. |
09-18-2014, 07:34 AM | #35 | |
09-18-2014, 12:19 PM | #36 |
I can't get the bike to start.......
I'm not sure what's wrong. I've tried different spark plugs. All I did was change the jets and change them back again when it didn't work. I checked the CDI by using the standard one as well. Does anyone know how to disable all the kill switches on the bike to test that. |
09-18-2014, 01:13 PM | #37 |
What readings do you get for standard prerequisites: fuel and spark?
After running the starter for a while, take out the plug, and check if it's wet? If yes, plug the cable on it, put its side ONLY next to something metal from the bike and crank the starter to see if there's spark. See this video for example: |
09-18-2014, 01:49 PM | #38 |
I'm not getting a spark from the plugs, or from a screwdriver as a tester....
I think a kill switch (safety) is stopping it. |
09-18-2014, 02:14 PM | #39 |
maybe the killswitch from the sidestand?
09-18-2014, 02:15 PM | #40 | |
09-18-2014, 02:54 PM | #41 |
I got it working.......... It was the cable from to the Spark plug............. it fell off at the start.
I spent at least ten hours today trying to get it to start. |
09-19-2014, 12:02 AM | #42 |
I'm sure that we've all been stumped like that.
10-03-2014, 08:13 AM | #43 |
Hi Again,
I had a party to goto in France; so I decided to ride the bike down... I rode from the Isle of Man all the way to Valence in Southern France when the engine exploded on the motorway! There is a crack along the entire engine and no compression. Ill take some photos later; but I have to cycle to the internet cafe 10km away on a friends bike. Im pretty sure the engine is dead: The piston still moves though. I spoke to a friend and he said I ran the engine too hard for too long. Im not sure though; I did about 1500 km ish in a row; it seemed to run fine the entire time and the fuel mix was 13.3 the entire way. Does anyone know what other engines will fit on the bike? I think I may need a new one. On the plus side it did between 120 - 135 km/h the entire way.... I think thats what killed it though: |
10-03-2014, 10:56 AM | #44 |
So sorry to hear that. At least you have a cool story to go with it; not many of us can say we were riding to a party in France!
You can easily bolt in a CG230 engine in, but the performance won't be quite the same. BTW, your engine is also about 230cc, AFAIK. You can also buy the parts on Taobao to repair your exisiting engine. I'm shocked that you were able to maintain 120-135 km/h!
10-04-2014, 02:51 PM | #45 |
Wow, 120 km/h is the "red" zone on the speedometer! I think you really pushed it too hard for too long...
