Old 05-29-2014, 01:27 AM   #1
hect75   hect75 is offline
hect75's Avatar
replacing speedometer bulb
I want to replace a burned bulb (speedo) and the neutral indicator. The speedo cable that is connected under the board, is tight and didn't want to remove with pliers (don't want to mess the speedo up). If I use pliers the cable can be removed; but I am afraid once the bulb be replaced, the cable will not fit or not tight again. What you guys recommend when replacing burned bulbs?
Cheers
Hector
Mountrack Vento 2006
Old 05-29-2014, 01:08 PM   #2
Don't worry, if you are careful, you can safely remove the speedometer cable with a pair of pliers. After replacing the extinguished bulbs, I suggest your replace the speedometer cable by hand; you don't need to tighten the cable very much for it to remain in place.
You can buy replacement bulbs for the speedometer and indicator lights at most auto part stores. You can also buy LED bulbs to replace the stock, incandescent bulbs. The LED bulbs will last much longer.
Old 05-31-2014, 02:02 AM   #3
hect75's Avatar
I will, thanks spud.
Hector
Old 05-31-2014, 02:38 PM   #4
pchitti   pchitti is offline
pchitti's Avatar
Second on the led option. Better view and life.
Search this Thread:
Advanced Search
Display Modes
