08-04-2007, 06:22 PM | #1 |
Like my new lights?
I'm just goofing off. I wanted to see what these lights would look like mounted on the bike. I actually kind of like the look. These are wide angle flood lights, but I'm thinking about using one flood and one spot (high and low beams respectively). They are avalible in 35 watt bulbs.
Oh yeah, if you'll notice the lights are held up with a yellow bungee cord. If they do get mounted for real I will make a proper bracket and enclose the wiring with a hobby box. |
08-04-2007, 07:32 PM | #2 |
I like'em! I would mount them a little closer together though.
I mounted up some car driving/fog lights on mine. Had them all mounted and wired up and then the bike's stator didn't have enough juice to power them. :evil: |
08-04-2007, 08:02 PM | #3 |
They look ok, Wonder if the bike can power them though...Give it a shot.
08-04-2007, 09:00 PM | #4 |
If I do mount them they will be closer together and a bit lower. One side will be the fluted lense flood like is on it in the pics and the other will be a clear lense spotlight for the high beam.
Pulling them should be no problem as GE makes the bulbs from 35 watts up to 100watts and they are only about $4 for the 35watt bulbs that I want. It's not so much about fashion as it is about being able to see... man the stock headlight stinks if you're doing more than 20mph a night. And forget about what's on your sides! That's why I like these flood beams, they shine way out to the sides, they illuminate evenly and they have a decent range. |
08-04-2007, 10:35 PM | #5 |
Hey, I gotta ask. Thats a 07 AL GY-5 right? I noticed your heat shield is different than mine. Are yours stock? I have a fat one that looks like an expansion chamber and on muffler I have the 2pc. chrome heat shield where you have a 1pc.
And I like that light setup. The low beam on mine don't do squat. I mean I can't see it at all. I'd be better off holding up a candle. The high beam is a lot better but I might be blinding on coming traffic .
Bone stock 2007 Lifan GY-5 |
08-05-2007, 12:00 AM | #6 | |
08-06-2007, 10:08 PM | #7 |
The BrainII, You have the same bike as knothead. Just a small change durring mfg. The style you have is most common. Also, as to the headlight problem, try turning the bulb 180 degrees. I have had no trouble with the headlights on these bikes for the most part. I have had to turn the bulbs on a few.
***I've seen mention a few times on here that folks were interested in HID lighting. I have a source where I can get one pair (2) sets of HID lights for all major bulbs, i.e. 9004, 9007 etc. for 300.00 per set. Includes all hardware needed. I'm not to interested in the mod, but if anyone wants to try it, let me know. Thanks
Brian Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com "Imagination is more important that knowledge" Albert Einstein |
08-07-2007, 02:45 AM | #8 | |
I'd love to have HID lights... but they are too much for me! I built an LED array tonight using some ultra bright whites I had in my parts box. 40 LEDs with a current draw below .5 amp... darn thing is blinding! I plan on building two lights using epoxy and Lexan for the housings... water, shock and vibration proof with a service life of 100,000 hours. I'll have maybe 10 bucks in them! (still not as good as HID, or even halogen, though!) |
08-07-2007, 12:37 PM | #9 |
Thanks for the tip Brian. Which bulb is the high beam. Is it the large center one or the small one on the side. I ask because I think my wires are hooked up in reverse. When the switch is on "High" only the small side bulb is on. Switch to "Low" and the large one comes on also. Easy enough to fix but just want to make sure I have the high and low bulbs correct.
08-07-2007, 02:23 PM | #10 |
The small bulb on the side is a "parking light". The large bulb should have both hi/low beams. Mine burned out after the first 100 miles.
Allen
08-07-2007, 03:11 PM | #11 |
Hey knothead, I like where you're going with this. Keep us posted. I like the look...very baja racing.
jason
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
08-07-2007, 03:46 PM | #12 |
Katoranger, Ahhh, I can see not why I thought my wires where hooked up wrong. It's the hi beam that's burnt out on the big bulb that made me think it was hooked up wrong. You say the little one is a "parking light"? It's on all the time. I'm not sure I get what this little bulb is there for if you either have hi or low on all the time....there is no off for the big bulb.
08-07-2007, 03:52 PM | #13 | |
#3 is the route I'd like to take, I have been looking at the factory stator and think it could be rewound for more power, but I can't find any sort of formula to estimate the power output. but then again, as cheap as the stock stator is I might buy one just to rewind it an see what I get. The bad thing is classes start soon and I'm going to be up to my eyes in calculus and linear algebra... it'll be something to do just whenever I have time. I've sent a few emails out, trying to explore options, but so far I have gotten no replies. |
08-07-2007, 04:02 PM | #14 | |
The bulbs are cheap from denniskirk and are much better quality than the stock ones. They also come in 45w too. Look in the cross-reference parts thread for the link. Allen
08-09-2007, 01:23 PM | #15 |
Hey guys, have not been on here in a couple of days.
Yes, I was refering to rotating the actual bulb. Sometimes this helps align the filiment more suted for the angle of the headlight. The HID's I found are $300 but I figured if 2 of you wanted to toy with that then it would not hit the pocket so hard.
