#106 |
This WR is still factory restricted..
3/4 throttle stop & the CDI has 2 maps in it WR & YZ still on the WR map , apparantly theres gray wire from the CDI to earth you disconect to switch to the YZ map... remove the baffle in the pipe.. resticted specs say 15hp 7,500rpm totaly un-corked 32hp 13,000rpm .. i will know in 3 weeks if it's mine or not...
#107 |
I just upgraded my intakes to stainless steel after i blew up the roller in the head. I did a piston change as well and found my top end was in really good condition otherwise. I don't know about making it 15,000 miles on a single ring piston with a 3/4 inch skirt though!
#108 | |
I know what you mean about the two-ring piston with the short skirt. I'm not predicting anything, merely hoping. ![]()
#109 |
Some of the CRF450 owners are installing a TRX450, 3-ring piston in their bikes.
![]() http://www.thumpertalk.com/topic/778...-in-a-crf450x/
#110 | |
thats a better looking piston but still a short skirt.. the WR250R has a long piston uses the same bore & stroke as the WR250f but is only a 4 valve motor... don't think you could machine a 5th valve pocket in the piston... with the right valves / piston / compression ratio theres no reason you couldn't make the motor last a lot longer. I looked at the WR250R but they are a 2008 onwards model and hold there prise... the WR250f takes a rekluse clutch.. edit.... just found this for a WR250F.. http://www.ebay.com/itm/350298522813...#ht_1134wt_932 full skirt 3 ring piston ... high compresion ,but a few base gaskets will sort that.. .....
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 06-02-2013 at 08:09 PM. |
#111 |
This afternoon I installed a Durelle Racing Gel Seat on my CRF250X. I purchased a Harbor Freight pneumatic stapler for the job, and when it worked, it worked well.
![]() After finishing the installation, I took the bike for a 31-mile ride to test the saddle's comfort. This saddle is definitely more comfortable than the stock saddle, and the saddle height is also definitely lower. ![]() Here's how the saddle looks mounted on my CRF250X. ![]() ![]() ![]() ![]() I buy a few things from Harbor Freight, and I have found some good bargains there. ![]() ![]() ![]() ![]() My first impressions of the Durelle Racing Gel Seat are very favorable, and I think it was a good purchase. ![]()
#112 |
It looks great! So, you delete the foam and use a gel pad instead?
#113 |
Thank you, Weld.
![]() The Durelle Racing Gel Seat is about 1-inch wider, and 1-inch lower than the stock saddle. Carving away foam reduces the saddle height, and inserting a gel pad in the foam preserves riding comfort. The Gel Seat comes with a new seat cover. You remove your old seat cover and foam from the seat pan. Then you install the gel seat and the new cover. ![]() http://durelleracing.com/store/index...roducts_id=306 I followed the instructions in this video to install my gel seat. ![]()
#114 |
that would be nice on my suzuki, but from the website it seems they only make them for hondas.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS ![]() |
#115 | |
The differences between the 'X' and the 'R' seem subtle but are important. Especially with the SS valves you have. FWIW I bought my YZ400F with maybe 30 hours on it. I have added about 120 to that, and 99% of those have been off road, and many of those demanding (sand dunes, paddle tire etc.) So, 150 hours total. I have checked the valves 2 or 3 times so far including about 6 hours ago. It has required not so much as an adjustment. It burns no oil and has all the compression and power of a new bike. With the way you take care of it, and your riding style, your bike will hold up fine.
Happy to serve. |
#116 | |
Happy to serve. |
#117 | |
I don't know what the YZ400F's piston looks like but it has a 5 valve head with stainless steel valves. I think Yamaha changed to titanium valves for the 426.
Happy to serve. |
#118 |
Yesterday I tested my new, Durelle Racing Gel Seat. I rode my CRF250X for 30 miles on pavement to the trail head, and the saddle was comfortable!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I'm very glad I bought this saddle! Riding for extended miles on pavement is now much more bearable, and the lower saddle height greatly facilitates crawling through boulder stewn terrain. ![]()
#119 |
Great mod!
I recognize that trail. Is that where Roger rode with one footpeg? BTW check your PM...
Happy to serve. |
#120 |
thats a nice bike mate... light & nimble
