03-10-2011, 11:46 PM | #1 |
2009 TMEC 200cc Enduro TMEC200-1
Just picked up a 2009 TMEC 200cc Enduro. Picked it up from a local dealer here in Muncie, Indiana - USA. Paid $1500 for it out the door tax included. Has just 1 mile on the odometer. Was able to title and register it as a motorcycle here in Indiana with the Certificate of Origin and the sales tax form.
Anyone familiar with these? What type of engine does it use? Has TMEC stamped on the side but it appears to be a Lifan 163FML OHV. But, it could be an OHC, I'm not sure. New to this. Appears to have dual piston brakes, front fork covers, rack, skid guard, street tires. Advertised top MPH is 75. Is this right or even close? Will be using this for a fun economical commute vehicle for back and forth to work. May need to change the spocket and gear to get the desired RPM for best fuel efficiency. Most speeds will be between 45-55 MPH and looking for @60-70mpg. Is this model a copy of a more recognized brand? Might help with parts locating. What all should I check, change or watch for being that it's new? Change the oil, tighten bolts, check for plastic wrap, any pinched wires, battery charged completely. What else? Here are a couple pics I took of the bike. Should drive it home this week as the weather is forecasted to improve. Been raining and cold as of late. Will post more pics soon! VT247 |
03-11-2011, 12:07 AM | #2 |
Nice looking bike! It was a great price, and it appears to have some fancy bits. Most of these are OHVs. Please post a pic of the left side of the motor and we can tell for sure.
Welcome to the forum!
Happy to serve. |
03-11-2011, 01:40 AM | #3 |
Welcome!
Nice bike. 8) I like the satin plastics, and the rear rack looks functional. I also like the Sachs Madass next to it.
03-11-2011, 09:01 AM | #4 |
Lots to like about that bike! I like the wide seat, gold rims and overall looks. The only minor drawback I see is a front fender that appears to be oversised.
Congrats on the purchase! Good price too. |
03-11-2011, 10:18 AM | #5 |
model name: tmec-200
engine: single cylinder, 4-stroke, air-cooled engine displacement: 196.98cc compression ratio: 9.2:1 bore x stroke: 63.50mm x 62.20mm max power: 14.08 hp @ 8500 rpm±350 rpm max torque: 9.96 lb-ft @ 6500 rpm±350 rpm engine oil volume: 1 l start mode: electric start ignition mode: cdi max speed: 75 mph brake system: hydraulic disk (fron http://www.roketmoto.com/WTMEC-200.htm Nice looking bike and a great price. I have four Chinese bikes that I have assembled from the crate and just do the oil change and battery prep plus checking chain tension,etc. Never do a wholesale checking of bolt and nuts. So far so good for me but since your bike has been put together by a dealer I would just ask them what they did and what they suggest you do. |
03-12-2011, 04:12 AM | #6 |
So, despite the weather, I drove it home today. What a cold ride! Got it home and idled it up some. Battery seems up so I'll leave it be. Changed the oil and recycled it. Dumped it down the gas tank of my Diesel Truck Here are a few more pics of the tires, brakes, engine and carb.
Which is the idle air adjustment screw? Thinking it would be to the side by the exhaust. What is the screw threading up from the underside into the carb? Took off the seat and checked the air box, looks good to go. Checked the wires and nothings getting pinched. There is a choke on the carb. I believe that with it all the way up is choke on, middle is partial and all the way down is open / run. Seems to idle good now that the idle speed is set, but would like to set the idle / air properly. Has 167FML stamped on the block and is pictured below. Where could I get replacement brake pads or parts in general for this Enduro if need be? Thanks! VT247 |
03-12-2011, 04:26 AM | #7 |
Welcome, and congratulations of acquiring your new bike, VT! The TMEC-200 has a nice, wide, comfortable saddle. You bike also has a very strong luggage rack. I got a close look at the TMEC-200 last fall, when I rode my Zong to American Fork, Utah. I posted photographs of the TMEC-200 about 3/4 of the way down the page at the following thread.
http://www.chinariders.net/modules.p...10887&start=45 You got a good deal. I believe you have an OHV engine, as Doc suggested. The screw you pointed at in the first photograph probably drains the carburetor float bowl. Spud
03-12-2011, 08:35 AM | #8 |
Okay, You have a pushrod engine. Nothing wrong with that.
The first carb pic is the bowl drain. Second pic with a screw is the air/mixture screw, and then your not pointing to it you see a horizontal screw with a knurled head. It will be on the right side of the carb. That is the idle adjustment. You have the choke procedure correct. If the bike starts easily in the cold it is probably set pretty close. Usually they are lean from the factory to pass EPA. Front pads shouldn't be a problem. Standard china bike, but I haven't seen a rear caliper like that before.
03-12-2011, 04:39 PM | #9 |
Spud, as a matter of interest for you maybe, the dealer here says Zhongshen engine!
http://mefast.com/TMEC200/200ccEnduro.html It is a 167fml OHV as you can see. You and others often say that zhongs are pretty solid, it would be nice to know if they are zhong engines. The Wuxi company may be making them for Zhong or round the other way of course! TIC I know we can look up some stuff from VIN but I just found out also that the emissions engine type code will unlock material too: 9TMPC 196TPI http://www.epa.gov/otaq/cert/veh-cer...r-02-01-10.csv this MAY help folk trying to register vehicles as well |
03-12-2011, 09:29 PM | #10 | |
03-13-2011, 04:38 AM | #11 |
Quick video of the Enduro. 8)
VT247 |
03-13-2011, 12:38 PM | #12 |
Thanks for posting the nice video, VT. The first screw you pointed at drains fuel from the carburetor float bowl. I think the second screw you pointed at is the pilot mixture screw.
03-13-2011, 01:49 PM | #13 |
We are going to expect more videos, now that we know how quick you post them! The bike looks better in the video than the photos. It seems that the TMEC bikes are somewhat popular in the UK in 125cc form.
I think these bikes can be the new Zongshen Sierra, Spud :wink: I think that VT247 might have started a new 'cult' for these bikes I found this on a google search for a contact for TMEC http://dealer09.mapyourshow.com/2_1/...markcamefrom=y It shows a contact in the outskirts of L.A. in Chino Hills, Calif. Wonder if they are still in business? |
03-13-2011, 07:41 PM | #14 | |
03-13-2011, 08:52 PM | #15 |
Nice looking bike, I want your wheels and front brake! lol
