4 wheeler wont start
my boy was riding his 110.... shut it off and now it wont start? it is only a couple of hours old... I checked all fuses, that little rip cord plug, it is getting spark I dont know what is wrong. anyone have any suggestions or have this happen to them?
try draining the gas, sometimes there is this gel like crap in the gas tanks when we first get them.. ends up getting sucked into the carb..
also on the bottem of the carb facing either the left or right side is a screw in the bowl of the carb.. if you turn it the gas in the bowl will drain out that little hose.. then pull the carb and turn it upside down and remove the bowl.. you will see the jets, unscrew them and make sure you can see through them. if you cant then clean them out and put it all back together.. run high octane gas in it for now on... |
Before doing anything, change the spark plug. The stock plugs are junk. A poor plug might spark when it's removed, but it can't necessarily spark under compression.
#4 | |
#5 | |
like they said above get a new plug
well it wasn't the plug so off with the carb
#8 | |
no i wouldn't start with a power pac and the battery is fully charged... it isnt getting any gas the new plug i bought is still dry and new after trying to start it over and over I took it to the shop that i bought it from and they are going to clean out the carb and get'er tip top for my son..
Let us know how it goes.
Some of these 110 cc's have a hidden fuel shut off in the line which is hard to see under the body kit. I can't imagine it'd get shut off if magically if it ran for 2 hours but strange crap happens. Come back and let us know what the shop says. My experience with these things is they usually overfuel not underfuel, but others have had blockages on here. |
well I went to the shop today where my sons 110 is and they said that it still wont start and that there is a valve in the carb that is stuck. But the lady said dont quote me that i would have to talk to the mechanic so I have no idea when my boy will get his wheeler back.
#12 | |
#13 | |
#14 |
it sucks becuz i got it last sunday and it has been in the shop for 4 days now my boy stands out back with his helmet on going brrrrruuuummm! LOL
#15 |
cant remember if you bought this new or used.. if you bought it new you should be able to do a exchange or something cuz with this amoutn of defect in it they should replace it or send you the parts free of charge to have it fixed
