Dragon Chopper (3/4 chopper)
Hey Bros,
I hope to start a place for people who got one of these bad ass motorcycles.Their is NO support at all.Save here. To start on my second ride the chain tenchener ripped off. something I think a pre check first ride could have stopped. The dealer said they checked it all out :evil: . The limited adjustments allowed me to get rid of the tenchener (after taking a link or two out) Front tire is a 70/70/15 and the rear....205/40/14...imposible to fined.So I did some MODs on the front fork brace and now have a 120/70/15.Looks beefy and cool the ride is better to.The rear tire as well as front had lumps in it so at 40 mph it would hop like mad. I got a BFGoodrench Drag radial coming Wed.I hope this helps (205/50/14) Ill post more latter I got a 15T drive sprocket I think I would like to go right to 17T I think I got a Lyfan clone :roll: ...163FML so..... I saw the chart for compatibility....so do I order a drive sprocket from all of them and see what fits???? I ll add more latter got to go to work at 2am. |
I believe my bike has the same engine. The 17T sprocket you find in the dual sport parts section should work fine. It will give you some more top end speed.
I want to see some pics of the bike with the BFG installed. Allen
Ok,
I got the rear tire on! It took 150+psi. :twisted: to get it to beed up! All lights are on and working.Rear fender is on and 90% done. I just have to paint it. Will get picks up soon.Still looking for a 17t drive sprocket. |
That's what we like to hear from you, Brother!
Keep pluggin', Tigertamer
07 H-D XL883C 06 LF 200GY-5 Yin and Yang CAUTION Obey The Traffic Regulation. Always Wear a Helmet. Don't Ride After Drinking Wine. Before Operation, Read The Owners Manual Carefully. |
Ok,
I got the rear fender painted, a black Dragon green 8) My noligy hot wire should be here Thur the 25th I got to take the rear wheel off and replace 4 rubber bushings that I have no idea where to find.Annnnnnnnd Sat. Dad is comeing over with camcorder.Pics. just aint enuf ![]() on this thing.Still looking for 17t drive sprocket.Ill call Bruce again. |
Got my Noligy Hot wire on.....seems to hit harder. Deff.throtel responce
improved.My Idle seems to still dance from 1500 to 1700.For the 50.00 Deff. a nice upgrade. |
Well I changed the main jet from 96 to 105.I also took the little "clip"
from the second "notch" from the bottom all the way down to the last "notch."Definitely runs and hits very nice.Pulls a little harder as well. I definitely need to check my valves. |
#9 | |
2008 SL200-2 |
Ill do it !!! But I just got a NGK plug 3 weeks ago.So Ill wait till info
comes in on the coil and get both. So.......while taking my carb apart I saw what looked like "rustdust" or maybe dirt.I cleaned out the carb with carb cleaner but 2 days latter I took it apart and It was starting again.Looking at the air filter I see that it is like "gawes."Very Very see through.I got a air filter comeing But I cant help but wonder If the gas is rusting out my tank. Here in Oregon it is law that moonshine must be added to the fuel at 10%.So Im hopen that its just dirt and the air filter will fix. If any body has info on this let me know.....how would you know your tank is rusting???? |
Do you have a fuel filter on?? If not, install one, then clean out your carb really well. Try switching gas. Maybe when you filled up, the station just received their gas and it stirred up all the crud in the bottom of their tanks.
As for your air filter, take it out, clean it well, make sure it's dry, then re-oil it with K&N Oil or any other good quality air filter oil. You can drain your tank into a gas container and then use a flashlight to try to look in your tank. I don't really see how you can "look" into the tank much to see if it's rusting, but you can try to do a visual with a strong flashlight. You won't be able to see the bottom of the tank though. :-( I know that DennisKirk sells something that allows you to "coat" your tank to stop rust, etc. Let me know how it goes.
2008 SL200-2 |
First, I got the hot wire from Noligy
And yes I got a new fuel filter yesterday so will see about that. Filter due today its not a K&N.But it looks kool.....we will see. Thanks for the tip on spraying my filter.Is not a K&N but that might have helped.And Ill drain tank after all fails and coat with that Denies Krook stuff. ![]() Well shoot I cant fined a flash light I could probably just use a lighter 8) |
#13 | |
As for coating your filter, only coat it if it's a gauge type of filter. I haven't heard of anyone coating a SS one, so I don't think that'll work if that's the type you got.
2008 SL200-2 |
#14 | |
#15 |
No pics yet? 8O
I thought for sure we'd get to drool over this by now! :wink:
2008 American Lifan LF200 GY-5 (930 km) - Sold 2007 Kawasaki EX250 - Sold 2006 Kawasaki EX650R - My new ride! 2005 Kawasaki EX250 - A new project |
