Old 08-28-2021, 03:36 AM   #16
Chris_Top_Her   Chris_Top_Her is offline
Chris_Top_Her's Avatar
Originally Posted by mototech77 View Post
I also did more research on the ECU diagnostic port. Looks like there are not missing wires like I thought. It appears now that there is power, ground and K-line data. I ordered a Honda 6-pin to OBD2 adapter cable. When it arrives, I’m going to verify the pin-out, then attempt to interface with my ELM adapter. Worth a try at least.
All you need is this https://www.aliexpress.com/item/Diag...27424c4d4kuVOq (als available on ebay) and a genuine or knock off tactrix open port adapter. ECu hud hacker is free to interface with the ECU.
Also I would reset fuel trims (d/c ECU for a bit) since you've made mechanical adjustments to the engine.
CSC RX4 2020
Old 08-29-2021, 11:13 PM   #17
7RC   7RC is offline
Did you ever adjust the valves?
Old 08-30-2021, 12:54 AM   #18
SuperNoob   SuperNoob is offline
My Lifan Xpect EFI tends to stall when cold,and occasionally when taking off from a light. This is happening just as I start to roll the throttle, before the clutch is engaged
I've noticed the same things with my 2021 X-Pect. It will be idling like a top, then suddenly just stall out like I hit the kill switch or something no warning at all.
Other times it's idling fine and I'll grab a bit of throttle in preparation for takeoff, but it will instantly stall out instead of revving up.
2021 Lifan X-Pect
Old 09-21-2021, 09:03 PM   #19
mototech77   mototech77 is offline
mototech77's Avatar
Thanks. That is not the right adapter, but I was able to locate a Honda compatible 6-pin OBD2 adapter that fits. It works with my ELM327 WiFi reader, connected to the Car Scanner iPhone app. I verified that the TPS was zeroed and I did find one error code related to ECU input voltage. I checked the voltage and found only a .10v difference, so I checked/reseated connections and cleared the code. Code never came back. I went ahead and adjusted the idle speed up some as others have recommended, which seems like it may have done the trick. The throttle body looks like it was machined for an optional IAC valve, but Qipai left it out of the design. I think this might help explain why these are finicky when cold. I say this because it seems to idle cold better if I adjust air bypass valve down when cold, but adjust it back out when warmed up.
Old 09-21-2021, 09:05 PM   #20
mototech77's Avatar
Yes, and I will probably recheck again before long based on other users’ experiences. This is a must on these bikes out of the box. Not the best manufacturing quality control
Old 09-21-2021, 09:06 PM   #21
mototech77's Avatar
That’s exactly what mine does. Wasn’t what I expected with EFI, but the idle adjustment seems sufficient so far (fingers crossed).
Old 09-25-2021, 06:32 PM   #22
mototech77's Avatar
As of the last ride, since adjusting the air bypass valve to increase idle speed, I did not have any more stalling issues at warmup or thereafter (fingers crossed). The idle is a little higher than I’d like it to be (about 1900), but it beats all the stalling.
2021 Lifan Xpect EFI
2012 DF250rtc
1982 Yamaha Virago XV750
1982 Honda Twinstar CM200
Old 09-25-2021, 07:37 PM   #23
Boatguy   Boatguy is offline
Boatguy's Avatar
Can you tell us where that bypass valve is?
2020 Lifan x-pect
Old 09-28-2021, 10:55 PM   #24
mototech77's Avatar
It’s the big flathead screw on the right side of the throttle body. Unlike a carburetor that would adjust the butterfly opening (this screw is on the left side), the air bypass simply allows more or less air to circumvent the throttle plate while leaving the TPS in the same zeroed position. Adjust counterclockwise to increase flow.
2012 DF250rtc
Old 10-25-2023, 09:09 PM   #25
Sdmfjon   Sdmfjon is offline
I realize this is an old thread but my 2023 x Pect is starting to have the same issue.
The spec plate on the side of the bike says 1500 +/- 100 rpm.
Ithe bike idles steady when warmed up and doesn't skip a beat. When it's cold it is stally.
I had the bike idling at about 1700 RPMs. Never had a stall issue until I adjusted it back down to 1500rpms. At 1500 it stalled once right after start up and once with a throttle crack. Might go back to 1700.
Valves at 0.06mm
Spark plug at 0.65mm
15w40 rotella jaso 2 certified
Has anyone else messed around with it?
Old Yesterday, 06:42 PM   #26
rideoutadv   rideoutadv is offline
rideoutadv's Avatar
Another addition to an old thread! I live in the PNW and it's currently Nov and colder than normal, around high 30's. Went for my morning commute today and my normally infallible xpect suddenly died on me. Rode for a couple mins and it died on me again at a traffic light. Noticed it was idling around 1400 RPM and dipping down to the 1100 range every 10 seconds or so. I never touched the little silver idle adjuster/air bypass or whatever it is, and it's always been fine, but I guess this is just too cold for the xpect. I put it in neutral with the bike running, took a flat head screwdriver and adjusted the idle screw up to 1600RPM and the bike seemed a lot more steady, no RPM dipping after the adjustment either. Will report back with further info after a few more weeks of testing is done. I'm thinking that this bike, even despite being EFI, gets slightly less reliable in the cold, but at least it can be mitigated back to 100% reliability.
Current Bike:
2020 Lifan Xpect w/ JT 17 Tooth Front Sprocket
Past Bikes:
2022 Honda Navi - Stolen
2016 Honda CB500x - T boned by idiot, totaled
? Honda CRF100F - 'Stolen' by grandpa
? Honda CRF70 - Sold to friends
Honda/Suzuki 50cc Kids Bikes - Sold to friends
Old Yesterday, 10:47 PM   #27
Make sure you check the valves on these.
I had to tighten my valves twice within the first 1k miles (they come right from the factory, but loosen during the break-in).
With proper adjusted valves, the xpect should be able to maintain idle down to 1.1k rpm, however, don't set it that low, even if it does idle fine.
Many threads about ruined camshafts due to too low idle (and not enough oil flow)
