Go Back   ChinaRiders Forums > General > News, Support, & Feedback
Old 10-21-2024, 10:21 PM   #16
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
They reused the YF300 engine code for the KE300F which is what they did with the Templar X 250 with the PR250(labeled it as "ZS172FMM-3A" even though it's a "ZS172FMM-5").
As for the panel fitment, I didn't even bother to tell X-Pro I just drilled out the plastic until they would bolt in correctly with proper fitment.
Don't worry about the oil weight, you won't notice a difference between 10w40 and 15w40. It's really your climate that determines what oil weight you should run but they dumb it down for the average consumer.
Old 10-21-2024, 10:26 PM   #17
LowBrewTow   LowBrewTow is offline
According to the Mototek/Zuumav page the bike weighs about 276 lbs dry which I believe over the powersports spec sheet that says 258 lbs. She feels like a big girl. It also says the max speed is about 75 mph.
What are you planning on using the bike for?
Old 10-21-2024, 11:07 PM   #18
No real plans, I couldn't pass up the $2600 price. I think you are correct with the 276 pound dry weight. I have an AJ1 A8 Pro which is basically the same exact bike that I bought before this one for a couple hundred less, it's weight is listed as 259lbs on my invoice. Although the specifications don't take into account the different engines, lighting packages, exhaust that are available. I should get that one delivered towards the end of Nov.
Old 10-26-2024, 08:19 PM   #19
rideoutadv   rideoutadv is offline
rideoutadv's Avatar
I'm interested in seeing if this bike will be able to hold a decent rpm at 70mph. If the KPX can do it, surely this can, or so one would think.
2020 Lifan Xpect - JT 17 Tooth Front Sprocket
2022 Honda Navi
2016 Honda CB500x
? Honda CRF100F
? Honda CRF70
Honda/Suzuki 50cc Kids Bikes
Old Today, 09:40 AM   #20
PhantomRider86   PhantomRider86 is online now
PhantomRider86's Avatar
This is great info guys thanks ! I just got my bike and I wanted to change the oil before riding it but could not find anything in the manual, so this helps out a lot. Also, knowing that the engine is a clone of the KLX engine gives a great reference point to start with.
