Old Today, 01:21 AM   #1
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
Hehe Storm 150 engine swap
The ZS190 is a bolt on affair, you will need a new clutch cable, fuel lines, oil cooler and lines, some electrical connectors and that's about it. You will want to remove the cat inside of the muffler for better exhaust flow which involves drilling out the rivets, drilling out some spot welds and then removing the catalytic cartridge. I just need to fit the rear brake lever back on before I get the jetting dialed in if it's not already on point from several people I have talked to. After that I will throw on the body work.
dlx 150, storm dlx, storm dlx 150, zs190
