Old 07-17-2024, 07:52 PM   #1
Maillmanmurry   Maillmanmurry is offline
Hawk 250 intakes on the exhaust stroke and vise versa
I recently got a cheap big bore kit and finally got around to putting it in. When I got it all put together it felt like it had no compression. Took the valve cover off and the valves seem to be acting irraticaly, and when I put my hand over the exhaust it sucks on my hand, and when I put my hand over the throttle body it blows air... I'm so lost, can someone help?
Old 07-17-2024, 08:41 PM   #2
Did you put a cam in when you had it apart?
If you did, then valve timing would be the suspect culprit. If not the only thing I can think of is that something is wrong with the way you have the followers installed. I don't think the jug would seat if the followers weren't spread out over the cam though. Did you actually feel the pushrods go in their sockets/cup? Are you sure both valve are completely closing?
Old 07-17-2024, 10:09 PM   #3
No I didn't. I only had as far as the jug taken apart. I'm pretty sure the pushrods are in the right spot. I kinda wiggled then around in the hole until they kinda pushed down snuggly and I couldn't wiggle them anymore. The valves were closing fully with the head off, I didn't check with it on.
Old 07-18-2024, 03:44 AM   #4
red2003   red2003 is offline
You DID re-adjust the valves when you reassembled it, right?
Old 07-18-2024, 03:50 AM   #5
Ummmmm... Would you laugh if I said no?
Old 07-18-2024, 07:00 AM   #6
I won't laugh. But that explains your symptoms. Both valves are too tight and bleeding compression into each other.
Old 07-18-2024, 08:06 AM   #7
bigdano711's Avatar
I was thinking he's 180* out. Err...he was on the intake stroke when he had it at top dead center and not on the exhaust stroke. I did this once with my Honda Accord when I changed the water pump/timing chain (related job). When I fired it up it sounded and ran like crap. I finally realized my mistake, corrected it, she ran fine.
Old 07-18-2024, 09:47 AM   #8
He can't be 180 out though, he didn't remove the cam.
Old 07-18-2024, 09:49 AM   #9
Still could be 180 out if the cam rotated in the head when the head was off the jug though
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 07-18-2024, 09:52 AM   #10
This is a pushrod motor, the cam is in the case, not the head.
Old 07-18-2024, 02:01 PM   #11
bigdano711's Avatar
I didn't remove the cam on my Honda, but still put the timing belt (not chain) on 180* out. Is that not possible with these motors? I honestly don't know.
Old 07-18-2024, 02:23 PM   #12
J4Fun   J4Fun is offline
I think it was explained in post #10.
Old 07-18-2024, 02:29 PM   #13
bigdano711's Avatar
Post #8 implies something else.
Old 07-18-2024, 02:35 PM   #14
The cam on these CG motors is gear driven, and sits right on top of the crank. That chrome button looking thing on the side of the jug/ cylinder is a short shaft that the cam followers go on. I initially asked if he had the cam out, because when the jug is removed, it's a good time to change the cam, because the jug has to be removed to get to the cam. I think a lot of people think the extra 20cc from a 70mm big bore kit is a game changer, but the head porting, and long duration cam is more effective. The cams are so cheap , and with the jug already removed, it's just an extra few minutes added to the job. I am not really worried about the cheap cams, but I have learned my lesson on the cheap roller followers. I have a stock motor from a parts bike on my Hawk now, and have been enjoying it just fine, but I do occasionally miss the extra power of my hotter motor.
