Barn find need help with ID and starting issues
I found this at a jobsite. Took carb off tank off and drained oil. Cleaned tank and carb. New fluid . Checked plug and it has spark but it's dirty. Will get new one when stores open.
Looking to see if anyone can tell me the cc of this engine as well as any specs on it. It was free so just would like to get it running and have some fun. |
Sure looks like an older version of the OHC 167FM
Do you see a model number stamped on the left behind the gearshift?
Theirs an engine number right next to the shifter. That will tell what you have.
Just got the barn find running. I have looked into it more. Says mainly a 200cc. It's a old Honda frame.
Thank you for all the help. I tried posting a short 3 second video put it won't let me. |
And what engine model number did you see on the left case behind the gear shift ???
