New member, new (to me) Lifan KPX 250
Hi everyone, new member. I just acquired a used 2022 Lifan KPX 250 with 1850 miles - that seller was the second owner. Original owner may well have been a forum member and follower of JerryHawk250 - since it came with a few of the updates on his page (wind deflector, chain, oil cooler (not installed).
Hoping that some members can aid me with a couple of things. 1. Previous owner dropped it and bent the rear brake pedal, it's been bent back into a mostly usable position, but I'd like to replace it. Any ideas where to get one? I don't see a replacement on Venoms website. 2. Is there any way to tell if the bike has had the ECU flashed? 3. Previous owner had the seat re done to be more of a flat, dirt bike style, they did a good job of it, but now it's higher. Unless anyone has any other good suggestions I'll order an original from Venom. Thanks |
Welcome aboard! If you contact Venom Motorsports, they should be able to get brake pedal for you. You can also try contacting American Lifan direct, but they will more than likely send you to Venom. I wouldn't worry about getting the ECU flashed unless you having issues with the bike stalling.
kpx250 |
