Old 06-07-2024, 08:40 PM   #1
cheesy   cheesy is online now
cheesy's Avatar
I've Got To Learn To Say No
My SIL asked if I could get his Dad's old mini bike going for the grandsons. I agreed. Idiot.
It's been sitting since the late 70s and needs a bunch of TLC.
Jake's Dad provided the red snowblower engine but it's a no go because it has a 1" shaft and the driver hub of the Salsbury 330 torque converter is 3/4". Luckily, I have a low hours B&S 5.5hp Intek taking up space.
It's apart now, awaiting new shaft bearings, chains, and other dodads.
I have no clue as to what it is. It's old enough for SAE fasteners and a big ol' Carlisle tire on the back. The front wheel isn't correct but looks like it came off of a Honda Monkey. It's the only thing with metric fasteners.
My back hurts.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 06-07-2024, 09:59 PM   #2
dirtbkr188's Avatar
I believe you're right, cheesy, it looks like it's from a '69-'78 Z50A, with a 4-bolt hub. Reach out to me if you consider hooking up a working front brake for it.
Old 06-08-2024, 03:11 AM   #3
I bailed on a similar project nearly a decade ago. Fortunately, it was my own idea, with no promises to anyone. Got it "running" with a 5hp Chinese Honda clone. But no front brake at all, rear friction brake not working right (yes, flat plate levered the rear tire) and then the rear axel severed at about 20 mph on pavement. Minor road rash and a quick Craiglisting quickly followed. Remarkably, recovered parts investment, minus labor involved!
Old 06-08-2024, 06:21 AM   #4
cheesy's Avatar
I did manage to find a manual online for the torque converter, so that's something, I guess. As it is Saturday, and probably going to rain today, I think I will stay away from it.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 06-08-2024, 01:38 PM   #5
I'm so glad you're here. Makes me look sensible once in a while.......
Old 06-08-2024, 07:47 PM   #6
dirtbkr188's Avatar
I'm actually working on a 1980 Honda Z50R for a good friend, it was in pretty tough shape. I have a bunch of parts here and also on order, but it ran when I picked it up from him.
Old 06-08-2024, 08:36 PM   #7
cheesy's Avatar
I'll keep that in mind. I think the original engine was 3 to 3.5 ponies. With the extra 2 HP from the Briggs and a lighter kid on it, I don't think the sketchy rear drum will cut it.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 06-08-2024, 09:39 PM   #8
jeffrey   jeffrey is offline
I think I found out what the brand that mini bike is,maybe a Herter Trail Mini. If that helps any. Also it came from Waseca,Minnesota.
Old 06-08-2024, 10:37 PM   #9
cheesy's Avatar
Originally Posted by jeffrey View Post
I think I found out what the brand that mini bike is,maybe a Herter Trail Mini. Ifthat helps any.
Bingo, Thanks.
I used to drool over the Herters Hunting Catalog as a kid. Once in a blue moon, I'd get to go to one of the stores. The last store I went to was in Eau Claire, WI forty years ago and they were just about done circling the drain back then.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 06-08-2024, 10:44 PM   #10
dirtbkr188's Avatar
I think jeffrey nailed it, click HERE
Old 06-09-2024, 04:27 AM   #11
Oh yeah. That's it!
I thought the Carlisle rear turf tire was an aftermarket thing. Clearly NOT. Wide flat tires don't lean properly on two wheelers, and takes some effort to control a turn- strongly resists normal countersteer leaning. I've heard horror stories from chopper owners. It may take some getting used to for the driver. Presumably a kid.
Old 06-09-2024, 07:10 AM   #12
cheesy's Avatar
Yup.
I showed Mrs.C some online pics and she said, "Oh, pretty. You need to repaint it back to the original red."
I thought to myself, "Aw, shit. This project just got bigger and more expensive."
T-I think this thing will be slow enough where the fat ass rear tire won't be much of a problem. The jackshaft is gear reduced and the Salsbury 330 torque converter is torque sensing instead of speed sensing. Apparently there were two versions of the TC. I'll be the first test pilot, anyway. Hopefully, the results will be less painful than the first run of the Kitty Kat snowmobile.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 06-09-2024, 05:16 PM   #13
Originally Posted by cheesy View Post
Yup.
Sorry about that.
Old 06-28-2024, 06:09 PM   #14
cheesy's Avatar
Finally got the driven clutch apart this afternoon. Three days of PB Blaster and hammer taps. When it came apart, it came apart now. Glad I anticipated that. I didn’t want a repeat of the 1952 Ford 3/4 ton leaf spring.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
