Old 04-26-2024, 07:06 PM   #31
I did order myself a few accessories for it today. Most of them coming from India and one from the UK. Most of them will be here in roughly 2 weeks, which is fine. I figure by that point I may actually be done with my break in and ready to do the oil and filter change. Most of the parts are Genuine Factory upgrades. Their black LED turn signal kit with flasher upgrade, sump guard, and a tinted flyscreen "windshield" for now. Nothing crazy.
I've also been looking at some cheaper saddle bag options just to have some cargo carrying ability. These caught my eye, mostly because of the price and the brand is an ok one for cheaper but decent quality as I have a tail bag made by them that is a few years old. https://www.ebay.com/itm/116083639223
Same Brand, very different look, size, and style, but I like them too. https://www.amazon.com/gp/product/B0...M9K7GWGH&psc=1
I am trying to decide if I want a tail bag or not, and if so, what kind.
Old 04-26-2024, 09:35 PM   #32
TominMO   TominMO is offline
All 4 of my brothers do look quite similar to me, but our voices are rather different, and I am the tallest and most good looking, obviously.
Uh.....yeahhhhh.....please pass on my condolences to the other three.....
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 04-26-2024, 10:14 PM   #33
Other 4. I'm number 3 out of 5.
Old 04-26-2024, 11:23 PM   #34
I'm the youngest of three country boys.....and obviously the best looking. ;-)
The youngest. Learn to fight the hardest and run the fastest.
Old 04-27-2024, 06:33 AM   #35
I decided to pull the trigger on these guys since they were only about 60 bucks.
https://www.ebay.com/itm/29591641959...01&mpt=8361645
Not an ideal design, but I am going to see just how sturdy they are, and I may make a small modification to add a little support to the back section with the rear seat subframe grab handle mount points if I think they are going to flex too much and potentially cause a problem.
I grew up the youngest. My older brother and I are the sons of our mother, the other 3 are my half-brothers from 2 different women. The oldest was put up for adoption when my father and his girlfriend had a kid very very young. The 2 youngest are from his second marriage after my parents separated.
Old 04-27-2024, 11:45 AM   #36
Does the Super Meteor and the Shotgun have the same frame???? Hopefully those bars bolt right on.
BTW, my 88 year old mom still has me up for adoption...... No takers.
Old 04-27-2024, 06:05 PM   #37
Yes, they do share the same frame architecture and swing arm/brakes. The Shotgun rear shocks are 20mm longer, the front forks are 30mm shorter, and the triple clamps are different. This is why the Shotgun handles so well, it has the same steering geometry of many sport touring bike, including my former vfr1200, with 25 degrees of rake.
The only real difference to the frame is where the Shotguns rear seat subframe bolts on, but the mount points these bars use are identical.
Old 05-01-2024, 11:00 PM   #38
I know a few of you saw my video on YT, but I may as well share it here too. Did my first service on it yesterday. Definitely a more complicated process to do a valve check than the Hawk since the tank has to come off... and the coils need removed, and their bracket needs moved out of the way all just to get the valve cover off, but at least it's nowhere near VFR1200 valve check levels of nightmare.
4 of my valves were tight/zero lash, an one set were at .02mm and the other was dead on spec still. I know that RE states the next service is at about 4700 miles, but I may check them again after the full break in period (1200 miles) is over. As much as I would love to just leave them alone, I just don't trust them until they have run longer than 291 miles.
I put in Castrol 10w-50 synthetic oil and a new genuine filter. I also installed a new pair of NGK Iridium CR7EIX plugs. I am keeping the OEM plugs as spares. I did find that my right side plug was actually not tight.
I also upgraded the turn signals to the Royal Enfield factory LED upgrades. I really like how they look, even though they do feel exceptionally cheap. For 99 bucks delivered for 4 direct replacement flashers and a relay it was a decent deal in my opinion. They definitely look a lot better.
Also, if you do find yourself with one of these bikes, or its brother the Super Meteor 650, the flasher relay is under a bracket, under the seat pan, under the seat. It's fun to get to.
Old 05-01-2024, 11:50 PM   #39
Do©Hawk   Do©Hawk is online now
Sweet bike, Dan. It's a looker, for sure. I'm still new to this motorcycle stuff, but Royal Enfield has really caught my eye.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / upgraded chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Debadged (I don't like to brag about the superior
strength!)
* Top speed, GPS verified, as equipped: 68 mph (so far)
Old 05-02-2024, 05:22 AM   #40
They are great bikes. Just the right amount of power to do pretty much everything, or as others might say "all the bike you need."
I like them because they are mostly metal. Tank, fenders, side panels, trim pieces on the throttle bodies - metal. Not many bikes below 10k can make that claim. Yes, they still do use plastic - the turn signals are definitely a cheaper plastic, but I can live with that.
The real masterpiece is the 650 twin. It's not the most powerful for it's size, but still a real gem of an engine. RE bikes aren't without some flaws, but as time has progressed they have started to really iron out the quality issues that they have had, and while not quite as cheap as parts for a Hawk 250, most of the parts are quite affordable.
I am curious to see what the Classic 650 is going to look like. It's basically a Shotgun 650 but with different tank, fenders, and spoke wheels to give it the real retro look many people want that the Shotgun doesn't quite give. The Shotgun is more of a Neo-Retro Bullet.
Old 05-02-2024, 11:33 AM   #41
I'm curious on the Classic 650, as well, not that my Interceptor is ever going anywhere. It's no secret I'm a huge fan of RE and have been looking for an older Bullet 500 for the herd. I think one would look marvelous next to my '48 Model G.
I'm glad to see you got the valves done. It's cake working on these compared to other bigger bikes. All RE's in history have been designed for owner maintenance and repair. My Model G is an absolute joy to wrench on. Nothing is hidden.
That's a smokin' deal on the blinker package.
Old 05-02-2024, 08:19 PM   #42
Doing the valves on the Shotgun is a nice couple hours hanging out. Doing the valves on my VFR was akin to using the force after taking the entire bike apart.
I also love how comprehensive that little tool kit is. It's a feeler guage set, a couple of sockets, a ratchet, and extension away from being able to do almost every basic maintenance task on the bike.
Those LED flashers are nice and bright, but they are definitely cheap plastic. The 4 pin relay is the real bargain as it's hard to find on its own. Eventually I may go with a set of Rizoma or Motogadget signals, and at least now I have the right relay for them.
Old 05-03-2024, 11:48 AM   #43
Yep. The relay is golden. When I converted my Scram to LED blinkers, no relay was available so I had to wire in resistors.
Old 05-03-2024, 09:32 PM   #44
Finding just the relay itself seems to be the hard part. The Relay part number is RXD00074/C, but when you try to find it they only bring up the entire flasher kit. Most aftermarket companies seem to be just selling standard relays with adapters or a kit to change the plug style on the harness.
Old 05-05-2024, 01:08 AM   #45
Darkrider   Darkrider is offline
So....this thread has me looking at the RE bikes again. The Hunter 350 and Meteor are a bit easier to swallow price wise with both of them being just under 7K according to the RE Canadian site.
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812 View Post
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
