Old 04-23-2024, 10:34 PM   #1
Homewrecker07   Homewrecker07 is offline
New owner of an Ice Bear Fuerza - what is this?
What is this lever on the left handle? It looks like a butterfly valve but I don't know what it is...
Old 04-24-2024, 06:47 AM   #2
Bruces   Bruces is online now
That’s called a “bond” lever ,if you are riding double and you have had enough of her ,you basically eject her off the bike and find another friend .They can also be found on Aston Martin DB6’s .
Old 04-24-2024, 06:53 AM   #3
Ha Ha!!
The teeny lever flashes your headlights, doesn't it? Is that the one you are asking about? It might flash the brights if the main toggle is on low beam.
The slider is choke (forward to choke).
Old 04-24-2024, 08:14 AM   #4
the on on the bottom is the turn signal switch. The one on top is to flash the bright lights.
Old 04-24-2024, 09:15 AM   #5
Ha Ha!!
Was asking about the slider. It's for a choke but disconnected as it's a different carb. Thanks!
