02-18-2024, 12:48 AM | #3796 |
Nothing..... being a good boy and saving my money...
02-18-2024, 08:43 AM | #3797 |
A CG clone variant 150cc engine.
Dry magneto, no electric start, no balancer 162FMJ for a re-power project. It will live in a 1981 Honda CB125S frame. Straight swap except for the top mount, luckily the CB frame has the mounting hole required for CG engines. https://imgur.com/a/WwxMykY |
02-19-2024, 04:19 PM | #3798 |
Finally converting my Templar X 250 to new tires for mostly street use which is what I use it for.
QTY 1 - Sedona Tube 18" (standard thickness) QTY a - Sedona Rear 110-120/100-18 QTY 2 - Sedona Tube 21" (standard thickness) - spare to cover both wheels in emergency QTY a - Sedona Front 80/100-21 QTY b - Sedona Front 80/100-21 QTY 1 - WPS Rim Strip 18" QTY 1 - WPS Rim Strip 21" QTY 1 - Kenda K761 Dual Sport Tire Combo QTY a - K761 Dual Sport Front Tire 90/90-21 QTY b - K761 Dual Sport Rear Tire 120/80-18
02-21-2024, 09:34 PM | #3799 |
I'll be doing the same eventually. My Hawk had brand new Track Masters on it when I got it and that's what I learned to ride on. I have no problem with them, but I can see the wear on them already. I'm not ditching them yet, but when I do, I want something more road oriented as that is what most of my riding is
2022 Hawk DLX EFI * 17T Front / 47T Rear / upgraded chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
02-29-2024, 03:01 PM | #3800 |
A 110VAC to 1.25-12VDC power supply kit. I need another power supply like I need another hole in my head, but I can put this one together.
I finished the DIY FM radio kit this morning after a couple of weeks of half assed troubleshooting. I got serious about it this morning and found the problem, a bad solder joint. It took longer to set up the solder station than it did to fix the joint. Turned it on, the display said 'HI' and the volume was at max. The neighbors probably heard it.
02-29-2024, 09:58 PM | #3801 |
Bauer 3ah 20v lithium-ion battery. It came with choice of a free tool and I needed a new circular saw so I grabbed the brushless 7 1/4" circular saw that was included amongst the free tools in the offer.
02-29-2024, 10:30 PM | #3802 |
A timing light and tach/dwell meter for the Corvair, I think the last ones I had were probably 3 decades ago
03-01-2024, 07:57 AM | #3803 |
I still have mine, Can't remember the last time i used them. lol
03-01-2024, 07:58 AM | #3804 |
I did that same deal a few weeks back. The saw works well.
03-01-2024, 08:40 AM | #3805 | |
Here's an upgrade you might think about when you find out that many new contact sets are crap. https://pertronixbrands.com/products...vacuum-advance
03-02-2024, 12:20 AM | #3807 |
2 Tires for the Chinese Aprilia ETX150.
Duro Star Monster , LOL.. Are a Chinese copy of a Kenda 761. both 110/90/17... couldn't find any smaller than 110 for the front... So will try the bike with same size front and rear.. .
03-02-2024, 09:04 AM | #3808 | |
You OK out there?
03-02-2024, 01:49 PM | #3809 | |
Plenty of oak on the porch to keep the wood stove going. Beer in the fridge and lots of dog food for Spot. Of course, the satelite dish is covered. Thank goodness for Bluetooth. Got some smooth jazz on the radio. What more does a guy need? We'll see how it unfolds over the next couple days. The ski resorts are supposed to get 12' of snow, in the next 24 hours. We''ll see how the prediction works out. The plow going by woke me up at about 4am.
03-02-2024, 01:56 PM | #3810 |
Lots of skis hitting the slopes! Iditarod attendees are probably happy they are well North of the worst of this!!
