Old 01-27-2024, 12:09 AM   #1
Jwinter   Jwinter is offline
Doh! Transmission fluid help for Coolster 175cc
Accidentally drained the transmission fluid when trying to change oil…do’h. The fluid that came out was green, replaced with red universal atf(bike shop guy said it would be fine.)
After replacing fluid couldn’t shift into drive / reverse, added more fluid and now it will shift but roughly.
Kinda nervous to take it out riding not knowing if I used the right kind or amount of fluid, any recommendations would be appreciated.
Old 01-27-2024, 07:25 AM   #2
If it's a GY6 engine, it will use gear oil and not transmission fluid. Post a picture of the engine.
2020 Kawasaki Vulcan S
Old 01-27-2024, 10:04 AM   #3
dirtbkr188   dirtbkr188 is online now
dirtbkr188's Avatar
Here is a pic of it from the Coolster website, it looks to be a GY6 engine...
Old 01-27-2024, 12:32 PM   #4
Yes that is the engine that dirtbk188 posted.
Can I drain and replace with gear oil…what kind?
Old 01-27-2024, 02:51 PM   #5
krat   krat is online now
It will usually be a 90# oil. It is available at any auto parts center or farm supply, or Walmart, just ask for "gear oil".
Most of those CVT units have two screws, one on top and one below it at the rear of the case. You drain through the bottom and fill through the top. Just pour the oil in until it is overflowing out the top filler hole.
Old 01-27-2024, 02:53 PM   #6
dirtbkr188's Avatar
I would suggest the Bel-Ray Gear Saver Transmission Oil (SAE 80W), made for wet clutches.
atv, coolster, transmission
