Old 01-11-2024, 02:44 PM   #1
2017hawk250   2017hawk250 is offline
zanella hawk digital cluster fuel gauge
i installed the cluster successfully this morning... everything is working fine speedo tach gear indicators...
but the fuel gauge was showing one bar with the light flashing... i went and filled her up and she is still showing the same thing... did i miss a step here?
how does the cluster get the fuel level info?
Old 01-11-2024, 03:18 PM   #2
bigdano711's Avatar
I believe it's in the 9-pin connector. This would be a straight connection, not the ones you had to pin. I would pull it all apart again and look at that connection. Unless you can get to it...I can't remember with mine. I suffer from CRS.
Just found my "manual". The 9-pin connector handles turn signal indicators, high beam indicator, neutral indicator light, fuel gauge, and speedometer. Are all those working fine?
Old 01-11-2024, 03:58 PM   #3
Did you remember to plug the connection under the tank back up? I discovered recently that on mine, it can take longer than expected to start reading the fuel level when ran really low.
Old 01-11-2024, 04:21 PM   #4
everything is working fine except the fuel gauge...
i didnt unplug anything from the tank... i hooked up the main connector at the headlight and ran the rest of the pins down to the gear/tach harnesses... i didnt see any reason to take the fuel tank off...
maybe my sending unit is bad?
