Old 12-06-2023, 03:38 PM   #16
Do©Hawk   Do©Hawk is offline
Originally Posted by Pharaoh View Post
okay okay do you think that this could be the problem? like maybe its being choked out and would that led to it not starting
I suppose it's possible, but I can't say for sure. (I'm handy, but far from a mechanic) I've only had my Hawk since August and that isn't a problem I've had. There is a crankcase breather that vents into the air box. This would be the source of oil in the air box. I don't know what atf fluid would do in a place where motor oil belongs, but hopefully your piston rings aren't toast.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / 428 x-ring chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Custom cutting board skid plate
* Debadged (I don't like to brag about the
superior strength!)
* Top speed, GPS verified, as equipped: 68
mph (so far)
Old 12-06-2023, 03:41 PM   #17
Pharaoh   Pharaoh is offline
Im more worried about my values being damaged or more being wrong i got it at 80 miles its at about 2500 now
Old 12-06-2023, 03:46 PM   #18
I wouldn't worry too much. Adjust the valves and do a compression and leak down test. Someone has been done on purpose before.
Old 12-06-2023, 03:49 PM   #19
Im not good at not worrying
Old 12-06-2023, 03:52 PM   #20
There is no choke on an EFI bike. There is an automatic enrichment made by the fuel injection system based on temperature.
Once you get the valves adjusted, if it starts I would let it warm up and dump that oil again. It will be contaminated with leftover automatic transmission fluid. Then put a fresh ~ one quart of good oil in it.
If it is still not running right after valve adjustment and fresh good oil, you may have some damage from running the engine with ATF. Rings probably, but also rod bearings, which are flat. The roller bearings on the crank may have survived. OK, so ATF can run hot. It is a pump oil. Yes, maybe short run is OK on ATF.
Maybe you even "cleaned" up the engine!
But get those valves right and yes, another oil change. YOu definitely want good oil in there!
Old 12-06-2023, 03:59 PM   #21
The optimal temperature range for transmission fluid is 175 to 220 degrees. Motor oil temperatures between 230 and 260 degrees. The ATF will lubricate just fine but will break down quick above 220 Degrees which is about the Temperature this engines run. ATF is a lubricant, otherwise every transmission out there would of blew up by now. lol Just follow the advise and do the valve adjustment before doing anything else.
Old 12-06-2023, 04:05 PM   #22
so my best course of action because the engine is so simple is compression test then valves adjustment if that doesn't go well then engine rebuild? and if that doesn't work either?
Old 12-06-2023, 04:07 PM   #23
alright ill do that and will be back tomorrow some time
Old 12-06-2023, 04:07 PM   #24
Valve adjustment first, cold engine. Compression test relies on the valves closing and opening on time. If it starts, good news. But warm it up and dump that oil/ATF mix. Then get new fresh oil in there.
Old 12-06-2023, 04:09 PM   #25
the battery is almost dead from start attempt but im about to post a video of me trying to start it
Old 12-06-2023, 04:11 PM   #26
okay okay got it thanks
Old 12-06-2023, 04:39 PM   #27
dead battery start attempt
https://photos.app.goo.gl/u1urcUKmjw58kQ4A8
Old 12-06-2023, 04:50 PM   #28
It looks like the clamp is missing on your exhaust....by where the kickstart folds up to.
2022 Hawk DLX EFI
superior strength!)
mph (so far)
Old 12-06-2023, 05:04 PM   #29
Zynice   Zynice is offline
When you kicked it, to me that looked and sounded like it has compression. Can send a video of what the motor looks like with zero compression (blown motor on my end). Didnt know you had a kicker lol. Are you able to easily move the kicker down by hand, or is there too much resistance on it?
2023 Tao Tao tbr7 (Mainly stock for now)
1998 Suzuki Intruder VS800 (bobbed out)
2021 Sur Ron Lightbee Supermoto (Heavily modified up to 40hp peak)
Old 12-06-2023, 05:31 PM   #30
yes i can move it by hand
#hawk250, hawk 250 electric start, hawk 250 motor, hawk dlx
